Old 16-05-2007, 12:06 AM   #1 (permalink)
sabret00the's Avatar
Default SLI drivers for 8600GT
I installed the drivers that came with my Zebronics 8600GT but the driver dosent support SLI.Futher,they are not "driver signed" by Microsoft.I need drivers that are "driver signed" by Microsoft for XP Pro SP2 and will also support "SLI".
Further,after I installed the drivers in Vista I got a blue screen and the system started rebooting after performing POST...evidently the drivers from axle3d.com are not at all XP or Vista signed and they dont support SLI at all....guys help!!!
C2D E6600,Asus P5N32 e SLI,1GB 667mhz,Samsung 940BW,Zeb 8600GT,Seagate 250GB sata II,16x Sony(OEM) dvd RW,Zeb Anitibiotic & Platinum 500W,Microsoft desktop pro 700,bluetooth,Logitech MX Revolution
sabret00the is offline
Old 16-05-2007, 12:10 AM   #2 (permalink)
shantanu's Avatar
Default Re: SLI drivers for 8600GT
http://www.nvidia.com/object/winxp_2k_158.22.html (windows XP)
http://www.nvidia.com/object/winvista_x86_158.18.html (windows Vista )
shantanu is offline
Old 16-05-2007, 01:42 AM   #3 (permalink)
^^^ thanx a lot bro...well another question is I have a Transcend Jetram 1GB DDR2 667mhz...will it support SLI or do I need specific SLI ready memory?
http://www.nvidia.in/object/winxp_2k_158.22_in.html (India pack for Windows XP)
http://www.nvidia.in/object/winvista_x86_158.24_in.html (India Pack for Vista 32)
Old 16-05-2007, 02:41 AM   #4 (permalink)
shantanu's Avatar
no its nothing specefic like this.. you can use your RAM its pretty good .. no additional RAM for SLI needed..
shantanu is offline
Old 16-05-2007, 02:50 AM   #5 (permalink)
then why does it say in the BIOS that no SLI ready memory detected?
Old 16-05-2007, 12:45 PM   #6 (permalink)
No pain....No gain
john_the_ultimate's Avatar
"SLI ready" certified memory gives better performance with SLI setup and currently is only supported by 590 SLI (500 series) chipset. For more info read this http://hardware.gotfrag.com/portal/story/32559/ Also it features EPP............more info on EPP http://www.simmtester.com/page/news/...ws.asp?num=151
Here is a review of SLi ready memory modules http://www.xyzcomputing.com/index.ph...sk=view&id=748
See if these articles help.
One more thing...........u could check the voltage and other stuff under the tab "POWER - Hardware Monitor" in your BIOS. Last time you were not able to find the options.
john_the_ultimate is offline
8600GT a joke, from nVidia (Discussion) Kniwor Graphic cards 11 13-05-2007 07:23 PM
XFX Launches 8500GT, 8600GT, 8600GTS in India Pathik Technology News 7 01-05-2007 01:55 AM
Help me with the drivers ? tiblu Hardware Q&A 1 02-06-2006 12:24 PM
Drivers for Win XP SP2 nishant_nms Software Q&A 6 01-12-2005 12:00 AM
