Old 14-05-2007, 05:02 PM   #1 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Exclamation USB controller not working on DG965RY
My uncle recently bought a new system with the following configuration. Well, thanks to Pathik for the configuration, we got it easily
Intel C2D 1.86Ghz @ 1066Mhz FSB
Intel DG965RY motherboard
160GB Seagate SATA II
2X512MB Transcend DDR2 @ 667Mhz
The rest is usual like DVD writer, keyboard, mouse, etc.
The problem is, the system is not able to install the USB drivers for the motherboard. Installed XP SP2 and all the drivers available on the CD given with the motherboard, but it still refuses to work Mouse also doesn't work in USB mode, so fixed it to PS/2 with the connection which came along. Here's a snapshot as to what is happening
http://tinypic.com/view.php?pic=6exb52q
Could anyone tell me how to solve this problem?
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 17-05-2007, 03:30 PM   #2 (permalink)
Default Re: USB controller not working on DG965RY
Check your Bios settings. USB may be disabled in BIos.
saigalp is offline
Old 19-05-2007, 07:18 PM   #3 (permalink)
phreak0ut's Avatar
No! The USB mouse was working fine until I installed SP2. Then, it stopped working, so I had to switch it to PS/2. Now what?
Old 30-05-2007, 04:37 PM   #4 (permalink)
phreak0ut's Avatar
Anyone who can help me out with this problem? Its urgent please!!
Old 30-05-2007, 04:44 PM   #5 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Why not download the new drivers from Intel Website
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 30-05-2007, 04:46 PM   #6 (permalink)
phreak0ut's Avatar
Its the same as the one provided on the CD, so not much help there
Old 30-05-2007, 05:10 PM   #7 (permalink)
Ethan_Hunt's Avatar
That's strange I have the same motherboard & processor & I didn't even have to do anything additional to get the USB drivers installed.It was just autorun the Disc & let it install all the necessary drivers & pump a manual restart.
V for Vendetta
Ethan_Hunt is offline
Old 30-05-2007, 05:22 PM   #8 (permalink)
phreak0ut's Avatar
Exclamation Re: USB controller not working on DG965RY
now, this is something. The USB ports work absolutely fine on Linux. I'll again check with the drivers on the site and compare it. If its the latest, I'll download and install. If not, I hope a reinstall might do the job. I hope!!
Old 08-06-2007, 07:34 PM   #9 (permalink)
phreak0ut's Avatar
Smile Re: USB controller not working on DG965RY
Well, I found a fix for this problem. I just rolled back the drivers for the USB ports only and its working fine now
Old 08-06-2007, 07:41 PM   #10 (permalink)
Let the music play.....
djmykey's Avatar
Hi phreak0utt
Check the link below.
http://downloadcenter.intel.com/filt...4&submit=Go%21
I bet that the 2007 drivers might have not come with the bunduled cd that came with the motherboard. Download the chipset drivers.
djmykey is offline
Old 08-06-2007, 08:00 PM   #11 (permalink)
phreak0ut's Avatar
Thanks a lot dj. I didn't know that the drivers could be old as I thought that the board was the very latest one. Gracias again senor
Old 08-06-2007, 10:37 PM   #12 (permalink)
djmykey's Avatar
Hmm good I got ur attention to it, but my question is r they working now.
djmykey is offline
Old 11-06-2007, 05:20 PM   #13 (permalink)
phreak0ut's Avatar
Yes, its working. Thanks
FEAR Intel DG965RY Motherboard Ratish_Pillai Hardware Q&A 11 07-06-2007 05:00 PM
Any difference between DG965RY and DG965RYCK????? preethesh.shetty Hardware Q&A 3 02-05-2007 01:08 PM
Intel DG965WH Vs DG965RY ? Innovator Hardware Q&A 22 15-11-2006 12:29 PM
Suggest me a nVidia 4 C2D & DG965RY Innovator Gamerz 5 13-11-2006 10:55 PM
sm bus controller cybermanas QnA (read only) 1 26-09-2005 03:20 PM
