Old 14-05-2007, 01:29 PM   #1 (permalink)
Default LG DVD writer H12n prob
hey guys and gals...
im with a prob..
i purchased the lg dvd writer h42n...
bt in the device manager the model number shown is h12n...is the first problem...thn
it reads the discs fine alright bt wen i try to write nething on a cd...
it gives an error sayin DMA ERROR, CRC ERROR...somewhat like this...
wat can this possibly be??
pls help me out..!!
manan
magneticme200 is offline
Old 14-05-2007, 01:45 PM   #2 (permalink)
Default Re: LG DVD writer H12n prob
in the device manager > IDE ATA > primary IDE channel > advanced mode. here change from pio mode to dma mode.
kooabs03 is offline
Old 14-05-2007, 03:17 PM   #3 (permalink)
its already on the dma mode only...
Old 15-05-2007, 03:38 PM   #4 (permalink)
Red face Re: LG DVD writer H12n prob
someone told me to search and update the driver of my drive...bt wen i try to update it...
the error shown is..
Updating was failed. Please repeat that. (Error data = 70 00 04 00 00 00 00 10 87 42 CA 00 08 03 00 00 00 00 6D 00 00 00
here is the log file status...wen i try to write a cd thru nero..
ktl
habnsf
1A23-0809-9130-2482-2482-3652
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 12:54:32 PM
NT-SPTI used
Nero Version: 6.6.1.4
Internal Version: 6, 6, 1, 4d
Recorder: <HL-DT-ST DVDRAM GSA-H12N>Version: UL01 - HA 1 TA 0 - 6.6.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <HL-DT-ST DVDRAM GSA-H12N >Version: UL01 - HA 1 TA 0 - 6.6.1.4
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SV4002H atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST380011A atapi Port 0 ID 1 DMA: On
CdRomPeripheral : HL-DT-ST DVDRAM GSA-H12N atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-H12N H: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 766MB (784880kB)
Free physical memory: 451MB (462612kB)
Memory in use : 41 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
15.5.2007
CD-ROM (ISO)
3:36:03 PM #1 Text 0 File Isodoc.cpp, Line 6475
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
3:36:03 PM #2 Text 0 File Burncd.cpp, Line 3012
Buffer underrun protection activated
3:36:03 PM #3 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 81920KB of Memory
3:36:03 PM #4 Text 0 File Reader.cpp, Line 124
Reader running
3:36:03 PM #5 Text 0 File Writer.cpp, Line 122
Writer HL-DT-ST DVDRAM GSA-H12N running
3:36:03 PM #6 ISO9660GEN -11 File geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
3:36:03 PM #7 Text 0 File Burncd.cpp, Line 3305
Turn on Track-At-Once, using CD-R/RW media
3:36:03 PM #8 Text 0 File DlgWaitCD.cpp, Line 281
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 1037 ( 0:15.62)
3:36:03 PM #9 Text 0 File DlgWaitCD.cpp, Line 293
Write in overburning mode: NO (enabled: CD)
3:36:03 PM #10 Text 0 File DlgWaitCD.cpp, Line 2612
Recorder: HL-DT-ST DVDRAM GSA-H12N
3:36:03 PM #11 Text 0 File DlgWaitCD.cpp, Line 459
>>> Protocol of DlgWaitCD activities: <<<
3:36:03 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1038 (1038) = #1038/0:13.63
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1036 blocks [HL-DT-ST DVDRAM GSA-H12N]
3:36:03 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [HL-DT-ST DVDRAM GSA-H12N] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 2433024, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1038 | lead-out | 1 | 0x41 | 0x00
3:36:03 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 1127
Removed 2 run-out blocks from end of track 1. Length: 1038 -> 1036.
3:36:03 PM #15 Text 0 File SCSIPassThrough.cpp, Line 38
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
3:36:03 PM #16 Text 0 File SCSIPassThrough.cpp, Line 83
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
3:36:03 PM #17 Phase 24 File dlgbrnst.cpp, Line 1685
Caching of files started
3:36:03 PM #18 Text 0 File Burncd.cpp, Line 4145
Cache writing successful.
3:36:03 PM #19 Phase 25 File dlgbrnst.cpp, Line 1685
Caching of files completed
3:36:03 PM #20 Phase 36 File dlgbrnst.cpp, Line 1685
Burn process started at 8x (1,200 KB/s)
3:36:04 PM #21 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
3:36:04 PM #22 Text 0 File Mmc.cpp, Line 21840
Set BUFE: Buffer underrun protection -> ON
3:36:07 PM #23 SPTI -1502 File SCSIPassThrough.cpp, Line 289
H: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1502)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x03
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 04 00 00 00 00 10 C8 35 81 80 08 03
Buffer x04220000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3:36:07 PM #24 CDR -1502 File Writer.cpp, Line 311
DMA-driver error, CRC error
H: HL-DT-ST DVDRAM GSA-H12N
3:36:07 PM #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
3:36:14 PM #26 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
3:36:14 PM #27 TRANSFER -18 File WriterStatus.cpp, Line 200
Could not perform EndTrack
3:36:14 PM #28 Text 0 File Mmc.cpp, Line 16608
<HL-DT-STDVDRAM GSA-H12N > start Close Session
3:36:49 PM #29 Phase 38 File dlgbrnst.cpp, Line 1685
Burn process failed at 8x (1,200 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 12/5/2005 10:42:26 AM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Last edited by magneticme200; 15-05-2007 at 03:38 PM. Reason: Automerged Doublepost
Old 15-05-2007, 03:48 PM   #5 (permalink)
check the data cable and the power cable of the writer. also which writing media are you using?
kooabs03 is offline
Old 17-05-2007, 09:28 AM   #6 (permalink)
thnks fr replyin..
wat do u mean by writing media here bro..??
r u talkin bout the cd im writing into???
well fr tht im using a sony cd-r...a normal blank cd.
and i dnt think thrs ne prob with the data or the power cable...coz the writer is perfectly reading cds and dvds/..!!
help me guys pls..!
y isnt nebdy up here to help???
i need ur expertise ryt nw...
Last edited by magneticme200; 17-05-2007 at 09:28 AM. Reason: Automerged Doublepost
Old 17-05-2007, 10:13 AM   #7 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Please check the DVD writer on another computer.
Harvik780 is offline
Old 20-05-2007, 03:44 PM   #8 (permalink)
pls pls...help me out..!!
i joined this forum with a lot of hope..!!
Old 20-05-2007, 11:03 PM   #9 (permalink)
Sorry To hear abt that dude.
Ihve only one solution for that uninstall nero then again install coz u hav writin prob no reading prob.
If this dont help then format ur computer
if this also does not help then throw ur Dvd Writer
Information Based on the above points.....
kushals is offline
Old 21-05-2007, 03:29 AM   #10 (permalink)
Wannabe_a_techie's Avatar
Don't give up that hope!
It could be something very simple....like different writing speeds for the disc and writer. Why not try and write a simple data DVD and then see the result?
If it's reading CD's and DVD's normally then it could be a writing speed issue....or maybe that SONY CD is damaged.
T
Wannabe_a_techie is offline
Old 21-05-2007, 10:17 AM   #11 (permalink)
is it also possble tht it only may write dvds and nt cds..??
can that b the case as well dude?
Old 21-05-2007, 04:56 PM   #12 (permalink)
UbuntuUser
cynosure's Avatar
^^ No. Every DVDriter can also write on CDs
cynosure is offline
Old 21-05-2007, 05:38 PM   #13 (permalink)
why r u writing cds at 8x. burn at atleast 40x. also use different media like moser baer.
kooabs03 is offline
Old 21-05-2007, 06:01 PM   #14 (permalink)
im writing cds at 32x only...is tht also too slw...alright thn i ll try writing at a higher speed and at a better media..!!
thnks fr advice..!
Old 22-05-2007, 08:35 PM   #15 (permalink)
You can try the following
1) Change the IDE cables, it may create writing problem even you can read cd/dvd perfectly. If you don't have the cable, try changing the ends of the cables.
2)If possible first try this writer in another working system. This will confirm that there is no problem in the Writer itself.
3) If not possible to have another system, try uninstalling nero and re-install it. Try with another software like InCD or usint utility in WinXp.
4) Scan your system for any virus that may cause problem in your system.
5) Format the system and install it fresh completly.
6) Finally your writer is defective, get it replace/repaired from the company if it's in warranty.
kuhupihu is offline
IE Prob spynic Software Q&A 1 11-02-2007 10:21 PM
help me with this prob :( tinku dhar QnA (read only) 6 27-01-2007 11:05 PM
Is it PSU Prob?....need Help!!!! archillies Hardware Q&A 2 03-11-2006 12:17 AM
Pc Fan prob.(Pls help this interesting prob.) Ishan Hardware Q&A 4 24-01-2006 09:38 AM
ONE more PRob champ_rock Open Source 5 17-10-2005 01:04 PM
