Old 13-05-2007, 05:37 PM   #1 (permalink)
Default Boot From Cdrom : No Emulation
IAM HAVING P4 1.6 ,ASUS MOTHERBOARD ,40gb hdd
when iam installing winxp pro sp2, it says NO EMULATION while boot from cdrom,what i have to do
i have checked my cdrom and hardisk both of them working fine when iam connecting to different motherboard
i selected my first boot device has cdrom and installing winxp ,its asking press any key to boot from cdrom ,if iam pressing a key it says NO EMULATION after that installation stops and cursor is blinking .what i have to do
asdfgh2 is offline
Old 13-05-2007, 06:14 PM   #2 (permalink)
Security Exp
47shailesh's Avatar
Default Re: Boot From Cdrom : No Emulation
Might be imcompatibilty issue with BIOS, get a BIOS upgarde and try again..
if you face probs again then repost
We Love Once, And When We do We do it Well
47shailesh is offline
Old 13-05-2007, 06:27 PM   #3 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
This might help.....
Correct..
I found out that Windows XP uses 'El Torito' Emulation for its Boot Discs... Maybe his BIOS doesn't support that emulation... A BIOS flash will surely make it work...
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad.. ;)
Last edited by kaustav_geek; 13-05-2007 at 06:27 PM. Reason: Automerged Doublepost
kaustav_geek is offline
Old 15-05-2007, 06:57 AM   #4 (permalink)
my bios version is 1008 , i uprgaded to 1009
the upgraded version 1009 looks different from the older version 1008
iam unable to select the boot device & it doesnt have an option of delete and f8 key to select my boot .
it automatically detects floppy and cdrom ,its not detecting my harddisk
what i have to do
thanks for the reply
asdfgh2 is offline
Old 17-05-2007, 12:48 AM   #5 (permalink)
Security Exp
47shailesh's Avatar
which BIOS do you have????
Old 17-05-2007, 06:21 PM   #6 (permalink)
updated :award bios ver 1009 updated one ,
older : award bios ver 1008
asdfgh2 is offline
Old 17-05-2007, 11:48 PM   #7 (permalink)
1337 |)00|) \m/
You mean the POST screen ?? Whats your motherboard ? Try this link.
My CDROM [A]bu Hardware Q&A 3 27-04-2007 03:35 PM
Emulation miltus_31 Gamerz 43 07-12-2006 02:02 PM
cdrom help bharat Hardware Q&A 3 02-04-2006 07:48 PM
question about emulation of windows softwares on linux sreevirus Open Source 8 08-10-2005 11:01 AM
No cdrom and no HDD skrbhatt Open Source 7 08-09-2005 10:53 PM
