Old 13-05-2007, 12:33 PM   #1 (permalink)
Smile any asus a8 nvm users??
anybody using this mobo?? have you tried oc'ing it??
Omsck is offline
Old 13-05-2007, 12:43 PM   #2 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Default Re: any asus a8 nvm users??
I personally don't have this mobo... But, its not hard to o/c it... Why ? Are you facing any problems oc-ing it ?
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad.. ;)
kaustav_geek is offline
Old 13-05-2007, 01:28 PM   #3 (permalink)
no ... but i cant inc fsb beyonf 240... thats the limit in the bios... .now its set to 240.....stock is 9*200=1800 nd now its 2167...acc to cpu z... also changd ram to 2.5-3-3-7 from 3-4-4-8... can i push it furter on stock cooling??? temp doest go beyond 40c
Omsck is offline
Old 13-05-2007, 01:37 PM   #4 (permalink)
1337 |)00|) \m/
Umm.. I don't think you should, even if you can.... I assure you, thats a very decent o/c... Anything higher will reduce the life of your board/CPU remarkably...
Anyhow, if you still want to o/c ... get SoftFSB ....
Old 13-05-2007, 01:43 PM   #5 (permalink)
GeekyBoy's Avatar
I'm an A8N VM user with an Athlon 3000+
I once tried to overclock it and it went upto 2 ghz.
GeekyBoy is offline
Old 13-05-2007, 01:44 PM   #6 (permalink)
okkk ... i wont try much then.. thanks
Omsck is offline
Old 13-05-2007, 02:55 PM   #7 (permalink)
assasin's Avatar
wat temps ur havin @ stock and @ 2167MHz??
if temps r within limit then u can easily oc beyond 2167.but dont inc ur vCore much in order to inc fsb.
just keep a tab on ur temps and the vcore.
assasin is offline
Old 13-05-2007, 03:01 PM   #8 (permalink)
@ 2167 temp is 35c ....wat r the temp limits?? . nd tell me one thing, as i inc the fsb, the ram freq also inc... what is the limit upto which the ram can can handle?? do i need to use the divider for mem clock??
Omsck is offline
Old 13-05-2007, 03:20 PM   #9 (permalink)
assasin's Avatar
yes use the divider to first underclck ur ram and then oc it.
just oc to 2.4 and post ur idle and full load temps
assasin is offline
Old 13-05-2007, 03:24 PM   #10 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: any asus a8 nvm users??
hey... i hav A8V-MX mobo with Athlon 3000+ running at 1.8GHz should i o/c so it increases performance of my system?????
will it help in gamin or anyother other stuff???? and someone mentioned tat if we o/c then life of the processor & mobo reduces it this true??
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 13-05-2007, 03:24 PM   #11 (permalink)
but here is a prob; how do i undrclk the ram?? there is no optin in bios...
Omsck is offline
Old 13-05-2007, 03:32 PM   #12 (permalink)
1337 |)00|) \m/
Why does he need to underclock his RAM ??
Old 13-05-2007, 03:53 PM   #13 (permalink)
@assasin, i limited ram to 166; fsb is now 266.8; 9*266.8=2401 .... ram@ 240... while writing these temp is 35... what should to acieve full load?? nd how much should the ram run at ideally??
Omsck is offline
Old 13-05-2007, 05:53 PM   #14 (permalink)
1337 |)00|) \m/
Run a few heavy duty games..... Anything heavy that you got.. Run them for about 20-25 minutes....Your system should peak at its full load.....
Old 13-05-2007, 06:00 PM   #15 (permalink)
"The Gentleman"
vish786's Avatar
@kaustav_geek
wat abut my query???? should i overlock... read my post on top
- Dijkstra
vish786 is offline
Old 13-05-2007, 06:18 PM   #16 (permalink)
1337 |)00|) \m/
Yes, o/c-ing will help you in gaming... But make sure that your system stays cool and stable... Else, you system life will reduce.. O/c fanatics will deny, but even o/c-ing within limits decreases system life.....
Ask, assasin for a detailed How-to o/c-ing...
Old 13-05-2007, 06:25 PM   #17 (permalink)
"The Gentleman"
vish786's Avatar
thanks a lot
- Dijkstra
vish786 is offline
Old 13-05-2007, 07:56 PM   #18 (permalink)
assasin's Avatar
oc ing ram is only good upto a certain xtent since it doesnt hav any sort of cooling and u cant get any info bout heat build up.so for normal ram its better not to oc too much.
since ram speen incs if u inc fsb,in order to achieve a high fsb after oc its better to underclock ur ram 1st so that the xtent of oc on ram decreases.
for a better under standing see my rig's config in my sig:
Default Speeds :
E4300 = 9.0*200MHz = 1800MHz
Ram = 667MHz
since to hit the 3GHz mark i had to raise the fsb to 333 from 200,the ram inc from 667 to 833.in order to dec the ram speed from 833 and to achieve 1:1 ratio i just underclocked the ram to 533 and then inc'd mobo fsb.
the result:
E4300 = 9.0*333 = 3GHz
ram = 667MHz
assasin is offline
Asus K8n-vm nishant_nms Hardware Q&A 1 25-07-2006 11:55 PM
ASUS or MSI anilthomas26 QnA (read only) 18 11-07-2005 09:46 PM
ASUS 5900Ultra or XFX 5900 ultra or ASUS 6600 or XFX 6600 ?? rachitboom2 QnA (read only) 1 07-03-2005 02:32 PM
ASUS 5900Ultra or XFX 5900 ultra or ASUS 6600 or XFX 6600!!! rachitboom2 QnA (read only) 1 06-03-2005 04:05 PM
3ds Max users or Maya users mad_gundam QnA (read only) 35 21-12-2004 04:26 PM
