Old 12-05-2007, 06:27 PM   #1 (permalink)
napster007's Avatar
Default Vista Prob
hello
i'm using 7300le as my gfx. i recently installed vista. when i try to install my gfx drivers it says the software is not compatible. i really want to work on vista what should i do?
napster007 is offline
Old 12-05-2007, 06:29 PM   #2 (permalink)
assasin's Avatar
Default Re: Vista Prob
which forceware version r u using?
use 158.xx.i'm using them and they work like charm.
assasin is offline
Old 12-05-2007, 06:43 PM   #3 (permalink)
sam_1710's Avatar
a direct link to the driver : http://uk.download.nvidia.com/Window...ernational.exe
this'll solve ur problem!!
sam_1710 is offline
Get ready for Windows Vista: Cheapest Vista compatible PCs gxsaurav Hardware Q&A 15 31-03-2007 03:26 PM
cheers!! Vista s relzn on jan30 wat bout halo 2 vista sanolution Gamerz 2 21-01-2007 03:18 PM
Windows Vista testers to get free copy of Vista blackpearl Technology News 1 17-11-2006 05:10 PM
Pc Fan prob.(Pls help this interesting prob.) Ishan Hardware Q&A 4 24-01-2006 09:38 AM
