Old 12-05-2007, 11:07 AM   #1 (permalink)
Default Help assemble a pc
My uncle wants to assemble a pc which will be primarily used for watching hd movies(.mkv format).He already has a Panasonic 1080p projector and a Sony 5.1 sound system(supports dts).So there wont be need for speakers as these are quite expensive and their sound rocks.The projector has a pc out(vga).The budget is 50-55 k.As it will be placed next to home theater setup, the cabinet should be attractive.I am still in the dilemma whether to chose Intel or AMD.Same goes for nvidia vs ATI as ATI hasnt launched its directx 10 series cards.Please recommend a good configuration.Any suggestion regarding the same will be apreciated.
divyeshashiya is offline
Old 13-05-2007, 07:58 PM   #2 (permalink)
Default Re: Help assemble a pc
OK I change my question - I want a core2duo based 50-55k pc which will be used primarily for multimedia.That okay?
Old 13-05-2007, 08:27 PM   #3 (permalink)
assasin's Avatar
E4300/E4400/E6420 depends on how much u wanna spend on proccy.
Asus P5B Deluxe/Asus P5N32-E SLi
2GB ddr2 667 dual-channel ram
2*320GB in RAID 0 config
Pinnacle internal Tv tuner card.
DVD-RW
if u wanna buy gfx card now then buy 8800GTS 320MB but i'll suggest u to wait 4 AMD-ATI to release their cards.
microsoft wireless KBD & mouse combo.
assasin is offline
I want to assemble a new pc. Yogeshsharma Hardware Q&A 7 19-02-2007 05:43 PM
Need Help To assemble pc under 30k..... Roy.7986 Hardware Q&A 7 17-01-2007 02:00 PM
Help me assemble a rig ~35K Netjunkie Hardware Q&A 23 24-10-2006 11:03 PM
Assemble a Laptop Tech&ME Laptops and Netbooks 5 23-02-2006 10:22 PM
Need help to assemble a PC ;) !! Ultra_Bloodshed QnA (read only) 13 24-09-2005 11:01 PM
