Old 27-05-2007, 09:44 AM   #61 (permalink)
clmlbx's Avatar
Question Re: blue screens while playing games
Originally Posted by kushals
Its simple yaar
Assuming that u are using CRT
In the monitor Menu Search for the option Degauss During the game.and execute it.it will surely solve ur problem
Solve hua tho thank u post karna nahi hua toh bhi bata dena
Afterall experience matters
firstly what is it ??
and what does it do ?
degauss
clmlbx is online now
Old 04-07-2007, 05:14 PM   #62 (permalink)
I'll xploit ur Territory
niraj trehan's Avatar
Default Re: blue screens while playing games
bsod HELP
hey help needed
read the dreadful story........
stage1
i got 7300gt , got vista ultimate and then pop up the dreadful blue screen started coming at the place where v have to enter our name......later stages i thot that can b due to ram conflicts.... i got that changed ..... bt nothing happened ....after some time i uninstalled vista and vas back to xp .... bt the story wasnt over...later stage of xp i starrted getting blue and red lines all over my screen.........
2nd stage
i got my grphcs card faulty vich was faulty,,,,,,,,,,,and gt 8800gtx xxx 768mb and then came prblem of finding the power supply vendor ..after moaning at forum i gt the place and gt the psu of coooler master and went home to c my rig working wid vista 1st time
in the place where we enter our password to enter the os
there is flickering and nt the blue screen
bt as soon as i click to upgarde my basic score which is 1(yet another problem)
i get blue screen or if i play any game eg spiderman3 i get that blue screen....physical dump memory....
i tried changing ram bt doesnt help....howver windows xp is fine.......
......bt again the blue screen......
can any 1 tell me whats this !!!!!!
thx for patient reading
my config
motherboard:intel 945 gnt
ram:2 gb
graphic crd:8800 gtx xxx 768mb
processor entium d 2.8
power supply:600w cooler master
can u plz give me link to the place frm where i can download the latest driver for my graphic card.....thx
<<XFX 680i TLi chipset>>Dual core 2.8Ghz>>2*1GbTranscend 800 hz>>8800 GTX XXX 768 Mb..GTX 260 862 Mb now GTX 280 1 Gb>>Cabbi CM 690 Nvidia SLI>>CM OEM 600w>>APC 1Kva UPS>>
niraj trehan is offline
Old 05-07-2007, 09:45 PM   #63 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Dude i can fairly understand your problem that u are facing coz i was also into the same kinda thing.
First of all here is a direct link for the drivers
http://www.nvidia.com/content/drivers/drivers.asp
U just have to select Graphics driver>Geforce 8 serires>(your operating system)>GO.
After all this i guess the problem lies into your motherboard.Just have to say that i believe if u have all the updated stuff except the motherboard and processor then i say why not upgrade it?
I know that not a possible great solution but this is the last option......but wait i still have something for you!
Its a kinda tricky one but something is better than nothing
Try your graphics card on any other system like if any of ur buddy have high end config. or u can ask the dealer to check it if he is a good (friend) human being (in most of the cases "NO").
Do this and you will come to a conclusion it will be the motherboard which has the confliction with the Card.
I mean u have the high end card and a low end Motherboard.
I guess there is a compatibility issue.
U should also read the FAQS of your motherboard from the INTEL site or use the Customer Service or check the web with the reference hardware(945 paired with 8800 GTX).
Good Luck my friend!!!!!!!!!
keith_j_snyder2 is offline
Old 06-07-2007, 01:44 PM   #64 (permalink)
thx for replying bt my vendor changed the mothrboard and that doesnt solve the problem.......actually bsod prob was of drivers bt nw a new prob has occured and that is that broken white lines r coming which ever thing is using graphics form the the graphic card......i wanted to post the pic bt cant shrink it to that small....
Old 07-07-2007, 10:14 PM   #65 (permalink)
Rising ApocalypsE
Upload it to http://www.imagevenue.com/
and paste the link in the forum.
Which games are you playing now? Charley Gamerz 387 14-01-2008 10:56 PM
Extent Of Playing Games pickster Gamerz 1 21-03-2006 08:21 PM
Playing PS2 Games On PC!! Orionz Gamerz 2 21-03-2006 12:24 PM
Playing PSx Games on PC iwant2breakfree Gamerz 4 20-01-2006 02:12 PM
help.about blue screens.random messages.no hibernation hippi QnA (read only) 7 05-01-2006 07:52 PM
