Old 11-05-2007, 11:54 AM   #1 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Widescreen Dillema
I want buy a LCD TFT monitor. But I am so much confused by hearing and
seeing about 17 inch normal TFT & 17 Widescren TFT, 19 inch normal TFT & 19 Widescren TFT monitors. 17 inch normal tft supports 1280*1024 resolution
and 19 inch normal tft supports same 1280*1024 resolution. Will not be text seen tiny on 17 inch TFT? For 19 inch tfts I think text will be seen a bit larger on that.
Guys get me out of this dillema
I have a Nvidia Geforce Fx 5200 GFX card on my board. Model is
Gigabyte GV-N52128DS. According to the manual this GFX card doesn't supports 1440*900 resolution ie that resolution isn't listed in the supported resolution list of the manual. Now I wanted know If I buy a widescreen TFT
will it work perfectly with my GFX card I mean if you guys have really seen a
widescreen monitor which resolution is 1440*900 working working flawlessly on a 5200 AGP GFX card then please inform in here.
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now
Old 11-05-2007, 02:49 PM   #2 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Default Re: Widescreen Dillema
Your Card supports a max resolution of 1024*768 ... So, I guess , a widescreen TFT won't work for you..
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad..
kaustav_geek is offline
Old 11-05-2007, 03:16 PM   #3 (permalink)
The Transcendental
^ Oh no. he can get a custom resolution with his graphic card using powerstrip.
I can get that resolution even with a riva tnt2, but my CRT doesn't do more than 1152x768@60hz\32bit. Dunno, i may be mistaken if this doesn't apply to LCDs but IMHO
monitor resolution should be your priority, esp. since graphic cards are more liable to be upgraded,
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 11-05-2007, 03:34 PM   #4 (permalink)
1337 |)00|) \m/
But, even if you can, I don't think the refresh rates will be bearable. LCDs have an issue with resolution and some of them don't support a resolution lower than their native resolutions . I suggest topgear to try out that LCD, if possible, with your card and see for yourself. It'll be the best thing.
Old 11-05-2007, 03:46 PM   #5 (permalink)
The Transcendental
^agreed.
if the monitor can do 1440x900 @ atleast 72 hz, it will be bearable. Surely 5200 geforce fx can do that. If it can't, it is just a bottleneck. You shouldnt buy a lower res monitor bcoz of your graphic card !!!!
1440x900 is a non native resolution for older graphic cards when widescreen were not as popular.
All new drivers by NVIDIA (5.xx) allow you to make a customized profile for your monitor via the ntuner and desktop manager and you can overrride default 4:3 resolutions and refresh rates. To get the rexolution you want, you'll have 2 hit and try. I would strongly recommend you to try out the lcd b4 buying too to checkout dead pixels, blacks, contrast etc.,
Old 12-05-2007, 05:44 AM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
My card supports a maximum resolution of 2048*1536 @85 Hz according to the manual. But 1440*900 isn't listed on their
Product page:
http://www.gigabyte.com.tw/Products/...ProductID=1240
Manual:
http://asia.giga-byte.com/FileList/M...n52128ds_e.pdf
Old 12-05-2007, 06:36 AM   #7 (permalink)
The Transcendental
Don't worry. it will do 1440x900 fine.
Try rivatuner or powerstrip or the default way as below:
Right click desktop > properties > settings > Click advanced > click the tab with the name of your graphic card (you should be using drivers from NVIDIA and not the default windows ones to get this tab, i am assuming you are using windows) > click refresh rate overrides > make your own custom resolution say 1440x900 60 Hz.
Apply the settings. check the resolution availability in your desktop settings. Steadily try different refresh rate first in blocks of 5, then 1 to get the maximum bang out of your card. For this to work, your monitor should support the resolution. Else, it will throw a sync error/ blank screen. Note down the last resolution. If Esc button does not get you out of the error screen, reboot in vga mode, after pressing F8 for safe mode options and set the highest refresh rate which did not show any error.
Since you graphic card can do 85 hz even at 2048x1536, you can safely use it at any resolution below the corresponding digits eg anything<2048 x anything<1536 @ 85 Hz. Phew. Thats enough.
Note. this should work to the best of my knowledge. Don't blame me if it doesn't
To err on the safe side, ask some nearby computerwallah to install the lcd at your home. Try this in his presence. If it works, problem solved, else ask him to take the lcd back. Make sure you check for dead pixels on the lcd too. They dont come under warranty.
best of luck for your purchase.
Old 12-05-2007, 08:02 AM   #8 (permalink)
U dont need powerstrip or rivatuner.
all nvidia (cards) drivers support custom resolution (if not update ur driver) & they detect the monitor resolution automatically & only then u will see 1440x900 listed.
For lcd u don't need higher refresh rate than 60 as it does not flicker.
ranjan2001 is offline
Old 12-05-2007, 10:23 AM   #9 (permalink)
1337 |)00|) \m/
oops... Pardon me. In such a case, there shouldn't be any problem... You can always create a custom resolution and refresh rate.
However, I think that as the screen size plummets, the effective maximum resolution dips.... Will have to check it though..
Old 12-05-2007, 06:56 PM   #10 (permalink)
The Transcendental
^yup
I just outlined the procedure if somehow his resolution is not detected, as with older detonator drivers.
Old 14-05-2007, 08:31 PM   #11 (permalink)
Fast 'N' Furious
topgear's Avatar
Thank U guys for your helps.I have the latest Nvidia drivers & I will not blame anybody For anything.
Do any of you guys have real experience with that card & with the resolution.
Also guys answer to this question:
Also if possible post some screen shot of 17 ich & 19 Inch LCDs
@1280*1024 resolution. With some text in the Notepad & icons on the desktop. So i can understand & see what is the difference between 19 & 17 inch lcd @ 1280*1024 resolution
----------Guys check out these (Sorry for off the topic link):
Permanently save priority of a process With PRIO
Old 14-05-2007, 11:11 PM   #12 (permalink)
assasin's Avatar
^^^ a 17" TFT @ 1280*1024 is perfectly readable.buy if u hav the cash go in for a 19" widescreen,u wont regret it later.
assasin is offline
Old 15-05-2007, 12:09 AM   #13 (permalink)
http://www.nvidia.com/object/custom_resolutions.html
I posted this link earlier too when I was having wide screen deliema & thats the 1st card I tested with viewsonic 19 inch wide screen on my old comp. I have no directed experience but used that for a day & then decided to buy a higher card xfx 7600GT
Old 16-05-2007, 05:55 PM   #14 (permalink)
Fast 'N' Furious
topgear's Avatar
If I want to go for a 19inch normal resolution tft ie 1280*1024, will that be OK? I mean can I see text & graphics perfectly and text & graphics will not be
seen so big.
@ranjan2001
What Was Your First Card? I mean name and the chipset or GPU name of that
card
Old 16-05-2007, 08:36 PM   #15 (permalink)
assasin's Avatar
^^^ if u wanna buy a 19" then its better to go for widescreen cuz u'll be getting a bigger display area.personally i liked the res of 17" as compared to 19" cuz both r same but only display area is bigger.
assasin is offline
Old 16-05-2007, 09:06 PM   #16 (permalink)
@ranjan2001
card
AFAIK it was geforce 5200 & that worked fine with 19inch wide screen.
Old 18-05-2007, 05:07 AM   #17 (permalink)
Fast 'N' Furious
topgear's Avatar
Thank You guys Very Much for your helps
Old 23-05-2007, 08:34 PM   #18 (permalink)
Fast 'N' Furious
topgear's Avatar
To Eliminate the issue of widescreen supported graphics chips- look at here:
http://ap.viewsonic.com/in/kbase/article.php?id=8
But
will text be seen perfectly readable on a 19 inch widescreen tft (1440*900) res with windows default 96 dpi.
will text be seen perfectly readable on a 17 inch tft (1280*1024) res with windows default 96 dpi.
Old 24-05-2007, 11:27 AM   #19 (permalink)
Yes if u still have some issue with the fonts then u can change the font size or the resolution of the fonts.I did so as mine is bigger wide screen running at 1680x1050
Old 26-05-2007, 04:47 AM   #20 (permalink)
absolutely
vikingboy is offline
Old 27-05-2007, 05:30 AM   #21 (permalink)
Fast 'N' Furious
topgear's Avatar
Finally got ie bought viewsonic VG921M 19 inch LCD TFT (not widescreen)
widescreen issue!! speedyguy QnA (read only) 8 29-04-2007 01:23 PM
widescreen LCD gksunil Hardware Q&A 3 23-04-2007 03:40 PM
TV tuner 4 widescreen 20inch LCD ranjan2001 Hardware Q&A 9 02-03-2007 11:15 AM
Sony Joystick Dillema!!!!!!!!!!!!!! Siriusblack Mobiles and Tablets 4 20-02-2006 11:35 PM
notepad dillema Generic Superhero QnA (read only) 19 15-08-2005 10:37 PM
