Old 10-05-2007, 11:49 AM   #1 (permalink)
damn busy...
utsav's Avatar
Unhappy dvd writer started working in pio mode
i have samsung dvd writer SH-W162Z .Earlier it was working in UDMA-2 mode.
one day i noticed that while copying data to the hard drive from the writer
it was consuming 100 percent cpu on my 3.0GHz P4 .I opened device manager and found the writer is working in pio mode.I flashed the firmware of the odd but then to of no help. Help me to correct the problem.Please.I am using xp.
utsav is offline
Old 10-05-2007, 12:39 PM   #2 (permalink)
rohus24's Avatar
Default Re: dvd writer started working in pio mode
hi
the same one existed in ma lg drive
i installed some raid driver from my motherborad cd and the soft dectected ma drive and put it in udma 2 mode
but den i found out the problem was in the data cable.
u cud even try enabling the udma mode frm the dev manager.
rohus24 is offline
Old 10-05-2007, 01:11 PM   #3 (permalink)
Dipen01's Avatar
Heres the link
http://www.station-drivers.com/page/jmicron.htm
and use the following version 1.17.11.02 WHQL..
And other main thing..check if ur cable is 40 pin..and if it is...ASAP change it to 80pin..even that caused the problem
I love walking in Rain ,because no-one knows i am Crying
Dipen01 is offline
Old 11-05-2007, 09:28 PM   #4 (permalink)
damn busy...
utsav's Avatar
Unhappy Re: dvd writer started working in pio mode
device manager was of no help as it does'nt correct the problem and there is no issue related to 40 pin or 80 pin cable. someone please help....
utsav is offline
Old 11-05-2007, 10:48 PM   #5 (permalink)
Still Shining!
Lucky_star's Avatar
Reset the DMA.
Use this tool: DMA Reset
Nokia N86 8MP
Lucky_star is offline
Old 15-05-2007, 11:24 AM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
whots a pio & udma 2 mode ?
by default, which mode ?
ax3 is offline
Old 07-06-2007, 03:14 PM   #7 (permalink)
CA50's Avatar
I encountered the same pro. Sol : Remove the cables, clean it, and insert it in another slot. Mine was solved in this way.
HAPPY HUNTING
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
DVD writer not working in Windows... crazy_sumi Hardware Q&A 4 10-04-2007 12:19 AM
DVD Writer is not working neelg22 QnA (read only) 7 01-11-2006 11:11 PM
DVD writer not working properly blacklisted Hardware Q&A 12 31-07-2006 10:40 AM
Why ain't this Safe Mode Working (XP) rahulstein Software Q&A 7 23-08-2005 07:03 PM
writer is not working fine sunil02 QnA (read only) 2 09-02-2005 01:17 PM
