Old 10-05-2007, 08:58 AM   #1 (permalink)
Question Suggest a Lappy please!!! (Kinda urgent guys!!!)
Hi guys,
my friend's buyin a laptop within this week (preferably today itself) and needs some advice.........
budget----> 45K max!!!
platform-----> Core Duo or AMD Turion X2
Brand------> preferably Compaq, but others like HP, Dell etc. would also do....
should have good support in Hyderabad
Screen------> preferably should NOT be wide screen
if u can please give the exact model number as it would be easier to find info bout it.......
I found a LOT of help around here when i bought a PC recently............ so guys please dont dissapoint my friend!!
preethesh.shetty is offline
Old 10-05-2007, 09:31 AM   #2 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Default Re: Suggest a Lappy please!!! (Kinda urgent guys!!!)
Most laptops now a days are widescreen and it is advisable to go for widescreen ones now.
No one beats HP in value for money. Strecth your budget a wee bit to 48 k and go for the dv2124TU. For specs, click here
On a second thought, I'd suggest that you look at these
May your friend get the best deal!
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad..
kaustav_geek is offline
Suggest me a good Lappy Pravas Buying Advice 4 23-03-2007 09:31 PM
lappy budget=Rs. 1 Lac...suggest the best Ishan Buying Advice 8 21-09-2006 01:57 AM
lappy budget=Rs. 1 Lac...suggest the best Ishan QnA (read only) 1 17-09-2006 06:29 PM
Which lappy ? (50-58k) [urgent] mohit Mobiles and Tablets 7 09-07-2006 03:37 PM
sony vaio lappy -> urgent help required adit_sen Hardware Q&A 3 06-12-2005 12:18 PM
