Old 09-05-2007, 11:14 PM   #1 (permalink)
Default Strange SATA issue
Hey folks ,this for all the people having SATA drives.I recently got myself a Seagate 160GB SATA HDD and its working fine.I also have a old Samsung 40GB IDE HDD that I have running XP.Now there is no OS installed on SATA drive.Here's the thing,when I load windows ,it detects the SATA drive as a removable drive with the "Safely Remove Hardware" icon in the system tray.
In device manager ,it shows up along with my other samsung drive. Is this normal. I also read somewhere that SATA II has hot swap function.Is this also true for SATA I ?? Any ideas??
And also i'm using the MSI K8N Neo4 -F mobo.
AMD 64 3000+(Venice Core),MSI K8N Neo4-F,512*2 DDR 400(Dual Channel),200GB HDD(40GB IDE + 160 GB SATA),GeForce 6800 GS,400W VIP PSU,Samsung DVD RW(DL),BenQ 17" LCD(FP71E+),Sony MDR XD-200 Headphones
roydon is offline
Old 09-05-2007, 11:15 PM   #2 (permalink)
nishant_nms's Avatar
Default Re: Strange SATA issue
it's no problem
nishant_nms is offline
Old 09-05-2007, 11:21 PM   #3 (permalink)
So you mean its normal? Is there anyway to disable the hot swap feature?
roydon is offline
Old 10-05-2007, 01:02 AM   #4 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Yes it's normal.........I also have 80Gb IDE (having the OS) and another 160Gb SATA II.
john_the_ultimate is offline
Old 10-05-2007, 08:48 AM   #5 (permalink)
digital2006's Avatar
Talking Re: Strange SATA issue
you can very well disable it
go to device manager>expand disk drives>double click on sata drive>go to policies>check enable write caching on this disk after selectin optimize 4 performance
PENTIUM D 820\GIGABYTE 945GZME\1GB RAM(533)\160GB SATA II HDD\SONY DVDRW DRU-820 A\THINKING OF BUYING A G CARD
digital2006 is offline
Old 10-05-2007, 11:27 PM   #6 (permalink)
Thumbs up Re: Strange SATA issue
@digital2006 ........ "optimise for performance " is already selected and thats the reason its showing the green arrow.But anyways since it is normal ,I can ignore it.
Thanks for all your help guys,appreciate it.
roydon is offline
Old 11-05-2007, 10:40 AM   #7 (permalink)
assasin's Avatar
^^^ just try to click on "Safely remove the Device" and see wat happens....
assasin is offline
SATA ROCKS : Fujitsu intros first 2.5" 7200 rpm hard drive with SATA 2.5 interface techtronic Technology News 7 22-03-2009 11:09 PM
Sata-II hard disk working at Sata-I mode Arsenal_Gunners Hardware Q&A 27 17-03-2009 10:18 PM
Can I attach a new sata drive to my existing Seagate 80GB SATA HDD? praka123 Hardware Q&A 6 04-02-2007 06:28 PM
How to connect SATA HDD to a mobo w/o SATA port ashnik Hardware Q&A 7 31-03-2006 08:52 PM
Strange! very strange..!! Where is the Problem ? Ricky QnA (read only) 8 11-04-2005 04:14 PM
