| Forum |
#1 (permalink) |
http://www.miraclesoftware.in Authorized Software Distributor - Online Software Shopping |
#3 (permalink) | |
same problem here but unfortunately i was twice bitten by the same bug. but you should not here- check if the pc cabinet has voltage running by switching off the pc & touch any of the metallic parts with a tester(not the painted parts) metallic parts mean nuts /bolts screwed to the cabinet. if tester detects the voltage that means there is earth leakage. this happens in most cheap upses . check & you may find that the line & neutral wire inside the ups hv been interchanged or there may b a problrm in yr house wiring(local electricians also unknowingly change the line& neutral in the sockets, this does not create problm for tv etc but it does for inverter & ups . what happens is that the battery loses charge even if ups is off & hence fails within 1 yr(avg life is 2-3 yrs) . I checked this but till then it was late, even my exide batt gone kaput . also check in any of the socket where you plug yr monitor etc put tester in the earth socket (the socket with a large opening in 3 pin ones) if tester detects voltage then it could b that batt potential is bein leaked to the earth wire get it solved at earliest else more appliances will malfunction
PENTIUM D 820\GIGABYTE 945GZME\1GB RAM(533)\160GB SATA II HDD\SONY DVDRW DRU-820 A\THINKING OF BUYING A G CARD |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| SMS Backup, is it possible? | Shasanka_Gogoi | Mobiles and Tablets | 12 | 13-04-2007 09:07 PM |
| Backup !!!!!!!!!!!!!!! | tehnogeek | Software Q&A | 1 | 25-02-2007 01:39 PM |
| Backup | Gaurav | Mobiles and Tablets | 9 | 25-10-2006 11:51 PM |
| I want 5 Hrs or More thn tht...Backup.. | hmmmmmmmmmmmmm | QnA (read only) | 9 | 28-08-2006 02:45 PM |
| registry backup means hd backup????? | magnet | QnA (read only) | 3 | 01-04-2005 11:00 PM |
