Old 09-05-2007, 11:31 AM   #1 (permalink)
MIT
Default Help : Building A PC.
All right a 60K PC with a cheap graphics card costing around 2K (I will upgrade to DX10 later).
Here's my initial idea:
ASUS P5N-E SLi ~10K
E6600 or E6420 ~12K
1GB of Kingston ~4K
250GB WD ~3.5K
LiteOn ~2K
Some cheap Graphics Card say, XFX's NVidia 6200 based. ~2.5K
Antec Super LANBoy ~5.5K
Some good PSU ~1.5K
ASUS 19" ~13K
Total ~54K
Suggestions and comments welcome.
MIT is offline
Old 09-05-2007, 11:50 AM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Help : Building A PC.
Altec Lancing ATP3 - best 2.1 IMHO
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 09-05-2007, 11:56 AM   #3 (permalink)
MIT
Price in Bangalore and just suggest changes in the config if any. Thanks a lot.
MIT is offline
Old 09-05-2007, 12:04 PM   #4 (permalink)
Host4Cheap.org
Price can be anywhere between 2500 to 3000 but quality is awesome. There was actually a review on ATP3. Cant find it.
Rest of the Config is Awesome Just that you can get 2GB of Kingston RAM for Rs 4000 and yes...get 2GB since Vista is a memory hogger but its nice OS
Old 09-05-2007, 07:46 PM   #5 (permalink)
Genius in making mistakes
bhushan05d251's Avatar
Samsung SE-S184M (ram, dual, lightscribe)
bhushan05d251 is offline
Old 09-05-2007, 09:00 PM   #6 (permalink)
harryneopotter's Avatar
lite-on is a smart choice ..... but the lightscribe version is a bit more costly ... all other things are spot on .....u can also opt for 7300/7100 instead of 6200.
harryneopotter is offline
Building a new PC indyeah QnA (read only) 3 30-10-2006 09:23 PM
Need help in Building a PC troubleshooter Hardware Q&A 11 17-04-2006 09:40 PM
HELP: BUILDING A NETWORK gary4gar QnA (read only) 1 03-10-2005 03:23 PM
Building a new rig jayavardanavel QnA (read only) 6 22-05-2005 04:47 PM
