Old 08-05-2007, 09:46 PM   #1 (permalink)
Fresh Stock Since 2005
Default What has happened to the HDD??
I'm Running Win XP Pro in a P4 with 256 RAM. I have a 40Gb seagate HDD (2 yrs old). When I install Programs, I usually get errors that the file is corrupted.. Actually the data gets corrupted very often...
I have scanned the HDD with HDD-Regenerator, but I found no Bad Sectors..
I even reinstalled XP. But the problem persists.
Help...
http://www.khattam.info
khattam_ is offline
Old 08-05-2007, 11:32 PM   #2 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Default Re: What has happened to the HDD??
1.) u maybe using pirated versions of the softwares.....
2.)there may be some virus that maybe corrupting ur files///..
3.)frequent power failures may also result into corrupting the files..
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 08-05-2007, 11:53 PM   #3 (permalink)
g_goyal2000's Avatar
Exclamation Re: What has happened to the HDD??
Your hard disk must have bad sectors.
If u'r file system is FAT32, then arrange a bootbale Win98 floppy or CD.
Boot thru it.
Then in command prompt, run the following command:
scandisk/all/surface/autofix/nosave
This will scan u'r hard disk for logical as well as physical errors and mark all the bad sectors.
Try running the utility 3-4 times as not all bad sectors get marked on a single run.
If it's NTFS, then run chkdsk /f/r.
Don't force a dismount. Press y to schedule it for next restart.
Repeat it for all partitions.
Now restart the system. And let the chkdsk scan & find & mark bad sectors (if any).
If that doesnt work, then use Seagate's Seatools program.
http://www.seagate.com/www/en-us/support/downloads/
Else use third party hard disk checking softwares.
If none of these work, then better backup what good data u have and get the hard disk replaced.
If there are bad sectors, then the above commands will mark them and recover all the data from them.
If there are bad sectors, then backup u'r drive contents onto any another drive. And get the hard disk replaced from Seagate Service Centre.
http://www.seagate.com/www/en-us/abo...t-contact-apac
They will replace it cos like u said u purchased it 2 years ago. That means u'r hard disk has 5 years warranty. Check it here:
http://support.seagate.com/customer/...validation.jsp
If it's not & warranty has expired, then u'r in bad luck.
Try taking the bill with u to service centre.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 09-05-2007, 11:55 AM   #4 (permalink)
Use Norton Systemwork to check the whole disk problem or try to yun defrag they will show you the status of the bad sector.
http://www.miraclesoftware.in
Authorized Software Distributor - Online Software Shopping
boosters is offline
Old 16-05-2007, 03:33 PM   #5 (permalink)
@khattam:
has your problem been solved? If yes, how?
Old 19-07-2007, 01:01 PM   #6 (permalink)
Originally Posted by g_goyal2000
@khattam:
no still there....
scanned for Bad Sectors, does not show any.
Tried to REMOVE bad sectors with HDD Regenerator, which also does not show any...
khattam_ is offline
Old 29-09-2007, 08:01 AM   #7 (permalink)
Ishan's Avatar
Can u please name the files which it shows corrupted?
Are they only system files? is the same file getting corrupted everytime?
Stop using all those regenerator softwares.
installed any softwares recently?
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 30-09-2007, 12:32 PM   #8 (permalink)
Your hard disk has most probably got corrupted.
Better if u back up the data in another drive (not partition) and get the hard disk reaplced.
The same happenned to a friend of mine & he eventually had to get his replaced.
Old 30-09-2007, 08:01 PM   #9 (permalink)
You may also want to check your RAM.Borrow a stick from a friend and see.
sashijoseph is offline
Old 30-09-2007, 09:28 PM   #10 (permalink)
Originally Posted by sashijoseph
You may also want to check your RAM. Borrow a stick from a friend and see.
I don't seem to understand what has RAM got to do with data corruption!!! If RAM would have been faulty, the computer wouldn't have started at all.
You could try one thing.
Backup u'r data on another hard disk.
And do a full format of the hard disk, not a quick format.
It will completely erase all of the data on hard disk by writing 0's to all sectors.
If this too does not help, then better get your hard disk replaced.
Old 01-10-2007, 07:36 AM   #11 (permalink)
Man faulty RAM can show weird symptoms.I've personally encountered two similar cases where the ram was faulty.In one case the mbr would get corrupted after each reboot.
The computer won't start if the RAM's totally kaput,but many times it will start and behave erratically...... restarts,freezes etc.
And he's scanned thoroughly for BS so no harm in confirming the RAM before purchasing a new hdd.
Old 01-10-2007, 05:02 PM   #12 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
just backup ur HDD as QUICKLY as possible ...... u never know when it will happen .........
& perform a FULL format ..........
... W H O T ...
ax3 is offline
Old 01-10-2007, 05:06 PM   #13 (permalink)
TechTin.com
ravi_9793's Avatar
Do you do regular disk cleanup and defragment???
ravi_9793 is offline
What Ever Happened To ...digit!!!!!!! kerthivasan QnA (read only) 1 07-02-2007 09:43 PM
how this happened the.kaushik QnA (read only) 5 02-09-2006 11:57 PM
Wat Happened ???? nipun_the_gr8 QnA (read only) 18 14-08-2004 11:32 PM
- by tv6952
- by soumya
