Old 08-05-2007, 09:17 PM   #1 (permalink)
Smile SMPS for Athlon 64 X2 3800+
I am using 300watt SMPS for my p4 machine.I want to upgrade to Athlon 64 X2 3800+.Can I use the same (300watt) SMPS ?
Golumolu is offline
Old 08-05-2007, 09:18 PM   #2 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: SMPS for Athlon 64 X2 3800+
offtopic: funny user name dude GOLUMOLU
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 08-05-2007, 09:26 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: SMPS for Athlon 64 X2 3800+
Am waiting for freebird here
Ontopic: Yeah you can use a 300 for it but tell us other details, like your GPU etc, cause it might need you to get a higher rated SMPS ..
Harsh J
www.harshj.com
QwertyManiac is offline
Old 08-05-2007, 09:47 PM   #4 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
i guess a 300w is a lil low, a 450-500w will be better, also if he is upgrading, he doesn't need to think abt it twice
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 14-05-2007, 08:31 AM   #5 (permalink)
Smile Re: SMPS for Athlon 64 X2 3800+
He he he .....I am always funny !
He he he he .......I am always funny !
Golumolu is offline
Old 14-05-2007, 08:35 AM   #6 (permalink)
left this forum longback
praka123's Avatar
dude!this is wrong section.this is open source,where Linux os and FOSS softwares are discussed.ask a mod to move it to Hardware section.It helps.
praka123 is offline
Old 14-05-2007, 12:43 PM   #7 (permalink)
@Golumolu
your old one may be around 2years old(that my guess) so better get a new 400w smps.
mobilegeek is offline
Old 15-05-2007, 06:02 PM   #8 (permalink)
Originally Posted by mobilegeek
@Golumolu
By all means get one with more wattage and preferably a better known brand.
From lesser known brands like Zebronics and Powersafe to well known and costlier ones like Antec, Coolermaster, Corsair etc.
Happened to see a Coolermaster 380W SMPS for just Rs.2100/-
Check the link below if interested.
http://www.theitwares.com/cabssmps/cabssmps.htm
V.Prem Kumar
janitha is offline
Help meee!!20 pin SMPS to 24 pin SMPS? sourav Hardware Q&A 9 25-09-2006 10:37 PM
pentium d 930 vs. athlon x2 3800+ ramana321388 Hardware Q&A 6 05-08-2006 06:59 PM
Zebronics 500W SMPS. Is it a good SMPS. Advice needed. Yoda QnA (read only) 4 13-11-2004 11:15 PM
