Old 08-05-2007, 05:39 PM   #1 (permalink)
Exclamation ATA Hard Drive Problem
I recently bought a new hard drive Seagate Barracuda 160GB ATA (ST3160215A) since my old 40 GB Seagate hard drive had developed bad sectors.When i used the new drive everything works fine except that i cannot install Intel Appliation Accelerator.My motherboard is an intel 845gevb2.When i install Intel Application Accelerator from the motherboard driver cd and after the system restarts the windows loading process never completes.Can u pliz help me out?Will not utilizing Intel Application Accelerator have any adverse effects on the system performance?
rexx is offline
Old 08-05-2007, 05:42 PM   #2 (permalink)
666
solomon_paulraj's Avatar
Default Re: ATA Hard Drive Problem
what OS you are using..
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS
solomon_paulraj is offline
Old 08-05-2007, 07:17 PM   #3 (permalink)
sam_1710's Avatar
^^^ : he is using windows! ..
Its ok if u dont install IAA .. !!
sam_1710 is online now
Old 10-05-2007, 05:24 PM   #4 (permalink)
Im using winxp sp2.will there be any performance degradation?By the way does seagate barracuda 160gb ATA (ST3160215A) support perpendicular recording?
rexx is offline
Old 11-05-2007, 11:01 AM   #5 (permalink)
666
Talking Re: ATA Hard Drive Problem
yes he is using windows, right (but what version dude)
got, it..
ok... with win xp sp2 you dont need to install IAA..
your drive supports perpendicular recording...
so you just set the settings in the bios.. no need for s/w accelaration...
Old 11-05-2007, 11:25 AM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
I also have one seagate one 160GB & one seagate 40GB on my 845GLM-AGP motherboard. OS is winxp sp2.
----------------Say what exactly solomon_paulraj said.---------------------
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now
Old 12-05-2007, 10:11 PM   #7 (permalink)
Topgear r u unable 2 install IAA just like i do?The BIOS doesnt hav any option such as setting perpendicular recording on.Do u think there is a problem wit my motherboard?IAA had worked fine with win xp sp2 on my old 40 gb hd.
rexx is offline
Old 14-05-2007, 08:16 PM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
If your bios detected the & show the full amount of your disk ie 160GB &
If you install winxp with sp2 ie (integrated) you don't need to install
IAA
Old 15-05-2007, 06:33 PM   #9 (permalink)
I had used IAA with winxpsp2 (integrated) on my old 40 gb seagate hd n i think it improved the performance by like 20 %.Now that the new hd is 160gb my system's gettin real slow.
rexx is offline
Old 16-05-2007, 05:24 AM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
I don't had such issue when I installed a 160GB HDD. Check in device manager if DMA settings is on for your primary IDE channel. Also if possible
try to install XP onto the 160GB HDD as master.
Old 16-05-2007, 05:43 PM   #11 (permalink)
Fast 'N' Furious
topgear's Avatar
Install Your 160GB HDD as MASTER & 40GBHDD as SLAVE on the primary IDe
channel ie IDE1. See your mobos manual to find IDE1 or primary IDE channel.
You have to set the jumpers of the HDDs properly for this.Check if your mobos
bios detects them properly. If not then clear your mobos CMOS setting by the mobos
jumper. Consult your motherboard manual for this. Now install XpSp2 integrated
freshly into the 160GB HDD. After installation don't install Intel chipset driver or
IAA from your mobos CD or any other place.
Open "System Properties" by right clicking in the "My Computer"
& select properties. or pressing windows_key+pause/Breake on the keyboard.
Go to hardware>device manager>IDE ATA/ATAPI Controllers. You should see a pic like this: Seee Image No ie Attachment No::1
select Primary IDE Channel &
double click on it. in the advanced settings box check if DMA mode is on. you should see
the picture something like this: See Image No ie Attachment No:2
if you see pio only then set them to DMA if Available. click ok and reboot.
your problem should be solved.
NOW INSTALL ONLY THE GRAPHICS DRIVER & SOUND DRIVER.
NEVER ISTALL INTEL CHIPSET DRIVER or IAA IF YOU YOUR OS IS WINXPSP2 In Intel 845 Chipset Family
Hard Drive Problem...plz help pokiriofap Hardware Q&A 3 26-04-2007 11:03 AM
RAM problem or Hard Drive?? hearthacker Hardware Q&A 3 28-03-2007 07:43 PM
Hard disk drive problem........ pushkar1986 Hardware Q&A 2 30-05-2006 02:13 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
