| Forum |
#1 (permalink) |
also...CPU-Z latest version shows my ram is always in slot 1 when i put 1 of my ram in any slot. there are 4 slots in my board. and when i insert the 2 ram, it also show that it is inserted at slot 1 and 2 even when i inserted at 3 and 4. BIOS is latest version...................... |
#3 (permalink) |
666
you have 4 DIMM slots..
consider like this DIMM 1 & DIMM 2 as A DIMM 3 & DIMM 4 as B now to use dual channel config.. you must use one ram in DIMM 1 and the other in DIMM 3 (i.e one is A and other in B, but you should use either 1 & 3 or 2 & 4 combination) also configure you bios for dual chan config
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS |
#5 (permalink) |
DIMM 1 and DIMM 3 is the right choice
the slots are color coded , go for 2 similar colored DIMMs
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB |
#6 (permalink) |
sometimes all the slots r of same color. also dimm1 n dimm2 may not b adjacent. that is why i told u to read the motherboard manual. here... this link might help...
http://tinypic.com/view.php?pic=4lzx9b6 |
#7 (permalink) |
666
dual channel works only if you put your RAM on
DIMM 1 & DIMM 3 or DIMM 2 & DIMM 4 if you put in DIMM 1 & DIMM 2 (or DIMM 3 & DIMM 4)it works only in single channel config..
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Is dual channel memory=DDR2? | 786 | Hardware Q&A | 13 | 07-04-2007 07:36 PM |
| Dual Channel Mode | keep_it_rl | QnA (read only) | 4 | 16-12-2006 05:09 PM |
| RAM in Dual Channel Mode | ashu888ashu888 | QnA (read only) | 8 | 16-11-2005 10:53 AM |
