hi, i need some information regarding PCI expansion cards..........
1>>>
i have been experiencing problems when using Dlink DSL router thru a usb2 port. so i want to use it thru a lan port. but my computer doesnt have one. it does have an ethernet card slot, on the mobo. but it is at the bottom-most point of my mobo. thus it cannot be reached from the outside.
hence the only option may be a lan port thru a pci card. is such a thing available?
also, say i want to connect computer A, to another computer B as well as a DSL router, can i use two lan ports on a single computer? so is a pci card with two lan ports available? what would it cost?
2>>>
i want to buy a pci card with "USB2 HIGH SPEED" ports on it. is a card with four "USB2 HIGH SPEED" ports available? what would it cost?
thank you
