hi guys i recently bought a new hard drive seagate barracuda 160gb ATA (ST3160215A) since my old hard drive 40 gb seagate had developed bad sectors.When i used the new drive everything works fine except that i cannot install Intel appliation accelerator.My motherboard is an intel 845gevb2.when i install intel application accelerator from the motherboard driver cd and after the system restarts the windows loading process never completes.Can u pliz help me out?
I think it would be your XP problem. Try to reinstall XP SP 2
first of all you dont need IAA for win xp sp2 as xp drivers correctly allocate dma to hdd
second problem could be your bios may not officially support 160 gb pata hdd ie in earlier 845 architecture 160gb hdds were not supported on 845 chipset
third fresh installation of xp
then first install latest chipset softwate from intel website for 845
second install graphics driver latest one
and dont install IAA
i can tell you all this as i have a old msi-845ge and a wd 160gb
