Old 07-05-2007, 03:45 PM   #1 (permalink)
Question Which PSU to buy ?
Hello,
I am very sorry for this repost . I waited for 2 days and none replied. Further I thought i was wrong in asking abt psu in graphics card thread.
I have a p4 3.00GHz proccy . Planning on buying 8600GT ( or some better amd card for the same money ) . I was waiting for the ati release . I want to buy a psu right now . My budget is max 2k . Which psu would suit these dx10 cards ?
Thanks in advance...
Again sorry for the repost.
Sagar
sagargv is offline
Old 07-05-2007, 04:23 PM   #2 (permalink)
Learner
Kniwor's Avatar
Default Re: Which PSU to buy ?
city dude... In India there is no good international brand are available, antec is out of ur budget, some local brands make decent PSU's tell ur city.
Kniwor is offline
Old 07-05-2007, 05:16 PM   #3 (permalink)
assasin's Avatar
in 2k u can get the zebronics 500w platinum.
assasin is offline
Old 07-05-2007, 05:19 PM   #4 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
go for zebronics platinum & wait a month or so for ati dx10 cards to be released......then u can get the best card
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is online now
Old 07-05-2007, 05:26 PM   #5 (permalink)
ratzee199's Avatar
go for POWERSAFE 500W PSU...it is good...though u hv to pay extra 300 bucks..otherwise go for TYPHOON..or Zebronics...though Zebronics PSU r not that good...
u can check www.itdepot.com...and www.itwares.com..for the prices...
ratzee199 is offline
Old 07-05-2007, 06:37 PM   #6 (permalink)
i can get the psu from b'lore.
a bit confused . two of u say zebronics . and the other says dont . Hmm.
moreover , any idea as to which maybe available ?
and what specification should i look for (if any).
thanks.
PS,
its like this . i've set apart 12k for the upgrade and most probobly i'm getting the gfx card from dubai . now i want to spend 12k this way .
7k - gfx card
5k - new mobo + psu ( 3k mobo and 2k psu )
i want a new mobo coz this mobo i have now(asrock 775dual915GL ) doesnt support vista. which indirectly means it doesnt support dx10 ( i think audio is unsupported in vista for this mobo as it aint high definition ) . this is the primary reason and i have another reason for mobo change . my current mobo has a agi express slot which happens to be a pcie x4 slot which would be a slight bottle neck for a dx10 gpu . as i mentioned earlier i have a p4 3.00GHz HT proccy . i was thinking of intel d915GAV mobo , its got a pcie x16 slot and high defn audio ,so it should support vista . any idea of its price ?
So , suggest me a mobo and psu which together will be less than 5k . Also , i have to go for 915 models as i have 1 gb ddr333 and i am in no position to change the ram. I suppose my position is a bit complicated . . .
sagargv is offline
Old 07-05-2007, 06:44 PM   #7 (permalink)
assasin's Avatar
u can also buy D101 if u can get it in the market now.
assasin is offline
Old 07-05-2007, 10:08 PM   #8 (permalink)
any idea abt its price (d101)? and what abt psu , i cant make a choice at all , with what the 3 of u have said . . .
sagargv is offline
Old 07-05-2007, 11:26 PM   #9 (permalink)
assasin's Avatar
D101 sud cost u bout 3-3.5k.
afaik Intel has stopped production of this mobo.
assasin is offline
Old 08-05-2007, 08:53 AM   #10 (permalink)
Unhappy Re: Which PSU to buy ?
i'll ask my vendor which he can get me . . . and in the meantime , what abt the psu ? do i go into zebronics . . .
sagargv is offline
Old 09-05-2007, 01:14 PM   #11 (permalink)
digital2006's Avatar
Thumbs down Re: Which PSU to buy ?
no!! never!!!!!
my frnd has burnt 4 zebronics psu's IN WARRANTY & the main cause was insufficient power.
dont go 4 500w. it is not actually 500w
instead as my frnd, go & buy any VIP OR NAVTECH MODEL(U WILL GET A DECENT ONE IN 2 K, ITS WRKIN ON HIS COMP NICELY)
PENTIUM D 820\GIGABYTE 945GZME\1GB RAM(533)\160GB SATA II HDD\SONY DVDRW DRU-820 A\THINKING OF BUYING A G CARD
digital2006 is offline
Old 09-05-2007, 06:38 PM   #12 (permalink)
ok , i'll try powersafe or vip and avoid zebronics.
thanks. . .
sagargv is offline
Old 10-05-2007, 01:12 PM   #13 (permalink)
Dipen01's Avatar
Same i would suggest...
Powersafe Gold Plated Dual Fan 500W PSU..
i bought it for some 2400/- in Jan
I love walking in Rain ,because no-one knows i am Crying :|
Dipen01 is offline
