Old 05-05-2007, 10:10 PM   #1 (permalink)
Be Healthy, Keep Smiling
Kaushal Hiwarkar's Avatar
Default BIOS not ACPI compliant
Hello
Recently I have purchased a motherboard (P-3 Intel 810E) with 128 mB Ram.
My problem is that when I tried to install XP or 2000 Professional I got message (BIOS is not ACPI compliant) and then installation failed. It also give message (Update your BIOS or Press F7 during text mode setup i.e, Press F7 key when you are prompted to install storage drivers.) I dont understand when I am prompted to install storage drivers also what is this text mode setup.
Plz tell me what is the real problem and how can I update my BIOS with step by step instruction
Currently I have loaded WIn-98 and all is fine.But whenever I tried to install XP or 2000 professional I face the above problem.
For your information In boot-up screen My BIOS name display is "Hendrix BIOS R0.04B"
PLZ help me ...............
Kaushal Hiwarkar is offline
Old 07-05-2007, 05:22 AM   #2 (permalink)
the_nanobreaker's Avatar
Default Re: BIOS not ACPI compliant
Please check it out :- Bios Update tutorial
the_nanobreaker is offline
BIOS not ACPI compliant Kaushal Hiwarkar Software Q&A 1 06-05-2007 03:10 PM
BIOS settings FOR ACPI shantanu Hardware Q&A 6 12-04-2007 04:41 AM
vista compliant graphic card ranjan2001 Graphic cards 21 19-01-2007 02:01 AM
Just to check if this forum is Unicode Compliant Aijaz Akhtar Open Source 12 26-04-2005 11:32 AM
ACPI error?Comp stops responding,please help! serendipiti QnA (read only) 1 10-12-2004 06:53 PM
