Old 05-05-2007, 01:55 PM   #1 (permalink)
godling's Avatar
Post Huge TFT Monitor
Posted to the correct forum. I meant to ask a few questions here:
Hi,
I'm into audio production, and therefore on the lookout for a large display.
My vendor in Calcutta is offering me an Acer 19-inch widescreen display
for Rs. 12,500. But I want to go for a 20" or more, preferably a 22".
He's also offering me a viewsonic 22" for Rs. 26,000. But that is turning
out to be a bit costly. My budget is Rs. 20,000.
My sole criteria is having lots of screen space.I want to know the following:
1. Does a widescreen 19" (or any inch for that matter) offer more desktop
space than a normal 19" screen?
2. What is the advantage of widescreen (if any)?
3. Does anyone know the approximated costs of the following?
- Samsung 22/21/20-inch TFT
- LG 22/21/20-inch TFT
4. Finally, what is the biggest TFT screen I can get for 20,000?
Figures would be really helpful, as I don't want to buy the wrong product
or get rooked.
Thanks in advance.
godling is offline
Old 09-05-2007, 08:14 AM   #2 (permalink)
Hulo's Avatar
Default Re: Huge TFT Monitor
Dunno abt 22" but I recently purchased one 19" Viewsonic one from M.D. Computers, G.C. Avenue. It cost me Rs. 11648 including VAT. (i.e. Rs.11200+VAT). U can chk this URL for some widescreen advantages - http://www.newegg.com/ProductSort/Ca...p?articleId=54
Somewhere I read that it is more cost effective for manufacturers - they can cut more widescreen pieces from their LCD slab than normal ones. Also, it is supposedly easier to look sideways than to look up-down.
Join IGNOU MCA Students' Forum -- http://www.santanu.in
Hulo is offline
Old 09-05-2007, 10:46 AM   #3 (permalink)
Still in war with allies
ssdivisiongermany1933's Avatar
Buy Asus 22 inch ,it is near about Rs 23500 with 2 millisecond Response
ssdivisiongermany1933 is online now
Old 09-05-2007, 11:51 AM   #4 (permalink)
MIT
Get two 740N (Samsung) which is 17" and set them up in dual-monitor setup. Should be costing ~20K. Also, they can be like a widescreen. Though do a bit of research about dual monitor setups and check if your Graphics Card supports. Cheers!
MIT is offline
Old 09-05-2007, 12:27 PM   #5 (permalink)
No pain....No gain
john_the_ultimate's Avatar
I was also looking for a single large display (i work with MAYA) but finally settled for dual 19" widescreen LCD. Cost would be more than 20K but definitely worth it. So for now buy a single 19" lcd wide/normal of your choice then later get the second one.
And if you decide to buy dual 17" lcd then don'y buy 740N, instead get yourself 740B (both analog and digital option).
john_the_ultimate is offline
Old 09-05-2007, 05:30 PM   #6 (permalink)
Buy the Viewsonic VX2025WM if you can find it. It should fit in your budget easily.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 10-05-2007, 01:21 PM   #7 (permalink)
godling's Avatar
Post Re: Huge TFT Monitor
Can you tell me the approximate price for this model?
Also wondering, the cost difference between 17" and 19" is so less,
but the cost difference between 19" and 22" is drastic, nearly double!!
Anyone has some idea why this is so?
godling is offline
Old 10-05-2007, 04:07 PM   #8 (permalink)
MIT
The 19" is the so called "current sweet spot" and 17" used to be so the prices are less. And also panel technology differ causing further increase in price. TN panel being the cheapest is used in most. The ViewSonic VX2025WM uses P-MVA Panel technology according to http://www.pureoverclock.com/article641.html
I am not sure of the price. Just Google about Panel Technology for more info. Again I would simply suggest a dual monitor setup. Weigh you options. Good Luck man.
MIT is offline
Old 11-09-2007, 05:22 PM   #9 (permalink)
godling's Avatar
godling is offline
Old 11-09-2007, 10:56 PM   #10 (permalink)
For having a rough idea-
Viewsonic 22" 2235WM Rs.17K
Viewsonic 22" 2245WM Rs.17.5K
http://www.theitwares.com/monitors/monitors.htm
V.Prem Kumar
janitha is offline
Such a Huge Debian? paragkalra Open Source 4 07-05-2006 08:41 AM
A HUGE Problem !! nipun_the_gr8 QnA (read only) 11 21-08-2005 04:42 PM
one huge problem yogi7272 QnA (read only) 8 10-05-2005 11:48 AM
