Old 04-05-2007, 04:29 PM   #1 (permalink)
Angry building agamng rig for 30000 plzz your valuable suggestion
hey hiii every one i am buying a new pc witha budget of 30000 but ther must consist a lcd screen . i will mostly be palying game like cs and nfs underground and ther grt games and surfing
plzz after hours of searching i got this confi will it play games
Components Model Price (Rupees)
Processor AMD Athlon 3000+ AM2 2,750
Motherboard Asus M2NPV-VM board 4,800
RAM Corsair Value Select 512 Mb
2,550
Sound Onboard5.1 channel HDA (Azalia)/AC97 Audio Controller N/A
LAN Onboard, Realtek 10/100/1000 N/A
Graphics Nvidia 6150 Onboard
N/A
Optical Drive Asus DRW-1608P3S 16X DVD Writer 2,150
Hard Disk Western Digital SATA II HDD 160 GB
2,650
Monitor Viewsonic VA1703W 10,050
Keyboard/Mouse Microsoft Keyboard and Optical Mouse Set 800
Case VIP 755 with 300 watts PSU 1,450
Speakers Altec-Lansing ATP3
2,550
Total Rs. 29,750
IS it reght configration or what should i do see i have a speakar and i dont need a dvd writter a cde writter is enough
THE SECONG CONFIGRATION WHICH IS IN DELL SITE IS THIS ONE
IntelŪ PentiumŪ 4 Processor 631 with HT Technology (with IntelŪ EM64T)(2 MB L2 cache, 3GHz, 800MHz FSB)
Genuine Windows VistaTM Home Basic
15" Flat Panel Monitor (15.0"v.i.s.)
512MB (2X256mb) DDR2 SDRAM at 667MHz
160GB1 SATA 3.0GB/s with Native Command Queuing
Free upgrade to IntelŪ PentiumŪ D 915 Processor with Dual Core Processing
Free upgrade to 1GB (2x512MB) DDR2 SDRAM at 667MHz
Rs 3,000 Cash Off which is abhout 32000 rs
plzzz i request u suggest me a rig plzzzzzzzzzzzz
hackers2005.3721 is offline
Old 04-05-2007, 05:01 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: building agamng rig for 30000 plzz your valuable suggestion
If I am not misstaking u will find it hard find single module of Corsair RAM's as they come in pair !!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 04-05-2007, 05:49 PM   #3 (permalink)
Shalu_Sharma
Posts: n/a
Ok you will be able to play underground + most wanted.
But dont think about Carbon.
Decrese the HDD size to 120 GB and spend saved money on RAM.
I suggest first config..
Old 04-05-2007, 06:22 PM   #4 (permalink)
napster007's Avatar
the first config is suitable for ur requirments. but when ur installing so much i strongly recommend to buy a gfx card. cut down on ur hdd.look for a bit cheaper lcd's and please put a gfx. u'll repent afterwards. i made a similar mistake. ati x1600 pro will fall in ur budget once u cut down on ur hdd and screen.
napster007 is offline
Old 04-05-2007, 07:29 PM   #5 (permalink)
deathvirus_me's Avatar
AMD Athlon64 X2 3600+ -> 3600
Asus M2N-MX -> 3600
Transcend 2*512 MB DDR2-667 -> 2800 (1400*2)
Liteon DVD-RW 18x -> 1800
Seagate Barracuda 160 GB -> 2600
Samsung Syncmaster 798MB -> 5800
IBall Multimedia Combo set -> 350
Creative Inspire 2.1 -> 1950
I ball GrabIt Cabinet + Elife 500W -> 1200 + 500
Total = approx 24000 ...
For the rest 6k's ... get a 8500GT ... can't suggest u a better combo ..
Plus the prices u mention are a bit on the high side ... check out http://www.theitwares.com/ for latest prices ..
With the rest u can get
deathvirus_me is offline
Old 04-05-2007, 08:25 PM   #6 (permalink)
The High 5 Flyer
sam9s's Avatar
1. If you are in to games even moderate gaming go for dedicated GPU. Any 6 series will do........but you gotta to have a dedicated gfx card...
2. Get atleast 1 GB RAM, get transcend if corsair is expensive.
Any any particular reason to go for LCD, If you ask me....... seriously the only benifit LCDs have is the space factor else CRTs believe me are as crisp and clear as any LCD. Infact the contrast and color reproduction that CRTs offer is far better than most LCDs. Also the resolution offer by CRTs are much more than what LCDs offer.
You can save a lot of money if you buy a 17" monitor or even 19". I'd say seriously consider this and invest more in GPU or RAM.
sam9s is offline
Old 04-05-2007, 09:44 PM   #7 (permalink)
UbuntuUser
cynosure's Avatar
^^ If youre really so much intrested in gaming then you can buy Xbox 360. 20000 buks and youre done for atleast 4 years.
Consider this only if you can do without a PC.
If I am not wrong then you can install any OS and do surfing and stuff like that. (Can do this on PS3, not sure bout Xbox, correct me if I am wrong guys)
Just a suggestion...
cynosure is offline
Old 04-05-2007, 11:19 PM   #8 (permalink)
assasin's Avatar
buy a crt instead of LCD and use the xtra money to buy 2*1GB ram.u'll feel the diff in games.
assasin is offline
Old 05-05-2007, 10:25 AM   #9 (permalink)
which smps will be suited for dx10 cards under 2k ?
@deathvirus , wich is that killer 500rs smps ?
sagargv is offline
Old 05-05-2007, 11:32 AM   #10 (permalink)
^^ Its an Elife 500W SMPS ... well , i know it cheap .. but its the only SMPS in that range that actually offers 20A across a single 12V rail ... compared to other 500 bucks smps , most of which are 400-450W , and offer only 17A across 12V .. Whatever it is .. that Elife SMPS is doing good running at system comprising of an oc'ed E6300 (to 2.8 GHz) , along with a 6800GT and a RAID-0 setup , etc. etc.
Old 05-05-2007, 12:57 PM   #11 (permalink)
assasin's Avatar
LOLZ.......my HP 250W (14A on 12V) psu does the same even though my gfx card is 6600LE and not 6800GT.
does the Elife psu has Intel EPS 12V connector??
assasin is offline
Need ur valuable suggestions...... devilzdad Open Source 8 28-02-2007 09:04 PM
Suggest Me the best Config upto Rs. 30000 shyamno PC Components / Configurations 6 17-12-2006 01:11 PM
your valuable suggestions needed. please help. quan chi Gamerz 6 04-11-2006 02:06 AM
another godfather problem please see this and post your valuable comments. quan chi Gamerz 1 12-10-2006 06:45 PM
Valuable Sites for Techies sreedevi Tutorials 15 04-10-2005 10:35 PM
