Old 03-05-2007, 01:16 PM   #1 (permalink)
Default Suggest a mobo!!!
Please suggest a motherboard with the following config -
Supporting Intel Pentium D and Core 2 Duo
2 RAM slots (supporting upto 2 GB RAM)
1 PCI - Express X16 slot
Onboard Sound
Onboard LAN
NO Onboard Graphics
Not high end - low to mid end...
Thanks
RisINg is offline
Old 03-05-2007, 01:42 PM   #2 (permalink)
assasin's Avatar
Default Re: Suggest a mobo!!!
wats ur max budget???
MSI P965NeoF = 7-7.5k
Asus P5N-E SLi = 8.2k
assasin is offline
Old 03-05-2007, 02:10 PM   #3 (permalink)
deathvirus_me's Avatar
MSI P965 Neo-F - < 6.5k's
Gigabyte 965P DS3P - < 9k's
deathvirus_me is offline
Old 03-05-2007, 02:14 PM   #4 (permalink)
Google Bot
Pathik's Avatar
asus p5b
gigabyte 965p ds3
Pathik is offline
Old 03-05-2007, 03:27 PM   #5 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
If you dont need high end...go for ASUS P5LD2
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 03-05-2007, 04:03 PM   #6 (permalink)
Will an Intel Pentium D 805 run on this mobo ? And I don't think this has onboard sound .. does it ?
thanks
RisINg is offline
Old 03-05-2007, 04:23 PM   #7 (permalink)
Host4Cheap.org
Which one, the one which i posted If yes, then.... Yes it supports Pentium D/ Core 2 Duo. Onboard Audio is like available on 95% boards these days
Old 03-05-2007, 04:28 PM   #8 (permalink)
ancientrites's Avatar
Asus P5N-E SLi
ancientrites is online now
Old 03-05-2007, 04:33 PM   #9 (permalink)
Host4Cheap.org
Originally Posted by ancientrites
Asus P5N-E SLi
He said, he doesnt want a high end MOBO
Old 03-05-2007, 06:20 PM   #10 (permalink)
Rebooting
Choto Cheeta's Avatar
is P5N-E SLI a high end board ?????
what would make a board hing end ?? i mean whats the line to to say bellow is mid range and above is High end ??
as with my budget a board beond 6k may look High end and again, to some one, a board of 10k may seem mid range
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 03-05-2007, 09:24 PM   #11 (permalink)
Well ,, whatever it is .. don't get anything lower than the MSI P965 NeoF ... for 6.5k's , u'll get features good enough ..
Old 04-05-2007, 12:15 AM   #12 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Most of the times the "NON ONBOARD display",motherboards are high end,u have very few choices as few of them are in front of u.
keith_j_snyder2 is offline
Suggest CPU & Mobo for a PC under 30k geek_rohit Hardware Q&A 8 17-12-2006 04:23 AM
Suggest Best Mobo for AM2 board boomstation2 Hardware Q&A 18 20-11-2006 02:34 PM
plz suggest intel mobo for cad/cam ashnik Hardware Q&A 2 07-02-2006 01:33 AM
PLS SUGGEST THE BEST MOBO, PROCESSOR, RAM !!! Vishal Gupta Hardware Q&A 28 23-11-2005 02:18 PM
plz suggest me..................regarding mobo and config.. vraja4u CPU / Motherboards 8 04-08-2005 09:49 PM
