Hi guyz,
I hav 2 PCs at my home.. They both hav AMD Athlon 64 processors and running Windows XP with SP2.. Both hav mobo's with onboard Ethernet (100 Mbps) and Firewire Ports (1394 - The Bigger Pin Type).. Additionally i hav a PCI Ethernet card wit me..
I hav BSNL Dataone bb conn.. They hav provided me a Huawei SmartAX MT882 ADSL Modem which has 1 ethernet and 1 Usb provision..
I want 2 set-up a home network with files & other resources Sharing between the 2 pc's.. I also want 2 share the net connection.. I want to connect 2 the net from either PCs even if the PC is switched off..
Is there any way to work it out without buying any additional equipment like a switch???
I thought of this method.. Pls lemme know if it would work.. PC1 connected 2 modem via USB.. PC2 via Ethernet.. Connect the 2 PCs via Ethernet Card of PC1 and the additional Ethernet card (connected to PC2) or use firewire..
Note: BSNL connection requires to dynamically acquire an IP address and other settings each time i connect.
