01-05-2007, 03:36 PM
Which Is Cheaper Or Expensive
Hi All,
Just as my Subject line says it...
which one is cheaper..
1. To Buy a branded Assembled PC....
2. To Buy a Non-Branded Assembled PC....
3. To Assemble One PC By Own Self Hands....
Please let me know this as i now am thinking of getting one..
so which option should i go for 1, 2, or 3??
Caje
01-05-2007, 03:41 PM
bang bang!
Re: Which Is Cheaper Or Expensive
I would choose 3
01-05-2007, 03:43 PM
Google Bot
if(u_mess_up)
Costliest :3;
else
Cheapest :3;
01-05-2007, 03:44 PM
Originally Posted by Chirag
I would choose 3
are you saying so because it is actually cheap to assemble one or are you saying this because we can choose anything we want for the PC?
Originally Posted by pathiks
if(u_mess_up)
Costliest :3;
else
Cheapest :3;
Pathiks can u please make up ur mind and let me know which one is the best option as u r confusing me man....
Reason: Automerged Doublepost
01-05-2007, 03:56 PM
Actually if u didn't goof up or get fooled, assembling a pc urself will prove cheaper then any other options(provided u get good deals) with the advantage of choice. So just try out ...but first decide ur configuration depending on ur budget and ur needs...
01-05-2007, 04:28 PM
Thanks for that advice man.. well to tell you the fact i want to build my dream machine.. that is the perfect and the last one for me.. no more after that so soon (For abt 5-8yrs) and i am thinking of doing this slowly i.e. buying part by part for the PC so that i can choose the most high quality stuff for my comp...
Thanks
01-05-2007, 04:38 PM
GUNNING DOWN TEAMS
actually iw ill say buy ur own PC hardware of ur choice...pay the shopkeeper 200 bucks and get it assembled by him...if ur not sure of ur self of assembling...then 3rd is cheapest..adn if u know how to assemble then it is more cheaper will save 200 bucks..
01-05-2007, 04:47 PM
Google Bot
wats ur budget caje?
01-05-2007, 06:33 PM
well pathiks just as i said that i dont want to look at the budget..
i have just started working at present so i will somehow manage from whatever i save to build up this PC Bit by Bit or as they say Byte by Byte
well there is no fixed budget... and also i dont want to go for stuff that is way too expensive also.. it should be of a good quality product... that does not mean the best.. coz i know it will be also very costly yaar.. and i have now just started to work.. so i have to save side by side..
it might take me some months to get this done.. but with all of you'll the help and support then maybe i can find things which i actually require and what has to be done..
Thanks
01-05-2007, 06:40 PM
Google Bot
k.. So assemble it on ur own.. How do u plan to start??
01-05-2007, 06:55 PM
i am thinking of starting with the Cabinet Ofcourse....
well i am now settled in Kuwait so over here there are some cases which are very cool... like for eg i saw one case which is totally acrylic and we can see throught it the entire interior of the system.. the cost is 18.00 Kuwaiti Dinar (which is equal to Rs. 2538)
05-05-2007, 04:39 PM
Here in Hyderabad, no need to pay 200 Bucks... Its free free free...
So, there is no much diff. b/w 2 and 3
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
05-05-2007, 04:47 PM
Dreamweaver
make it urself man... its cheap i've assembled more than 14 PCs for our cyber shop since 2005
05-05-2007, 05:11 PM
TechTin.com
If you are new abt hardware and PC troubleshooting..I will recommend you branded.
If you are expert,than asseble ur self.
There is not great diff in price.Branded are alao available in very affordable price with full support.
05-05-2007, 05:32 PM
^^^ but u wont get much choice in config if u buy branded other than DELL
05-05-2007, 06:09 PM
TechTin.com
yeah U may be right upto sm extent.But there is always room of upgradation in branded system also.Just pay few more and get upgraded.
And morever,branded system has many config to suit ur need.There was a time,when people don't prefer branded only because of high price.but time has changed,Branded are available at very comparable price.
Reason: they have to be in market ,they buy hardware n software in bulk,so they can manage low price.
05-05-2007, 07:28 PM
Seriously dude, get yourself a Mac Pro or a 24-inch iMac.
You'll later thank me for recommending it.
05-05-2007, 09:43 PM
#19 (permalink)
bang bang!
Stop spamming in every thread.
05-05-2007, 11:05 PM
#20 (permalink)
Can't such posts be removed by mods?
V.Prem Kumar
