Old 01-05-2007, 08:32 AM   #1 (permalink)
Q6600 Underclocked
sourishzzz1234's Avatar
Cool Dvd Rw + Cd Rw
Hi guys just yesterday i bought a SONY DVD RW(Rs. 1845).....
But the problem is tht previously i had a LG CD RW...
Whenever i tried to make the CD writer it failed please help
sourishzzz1234 is offline
Old 01-05-2007, 10:09 AM   #2 (permalink)
Default Re: Dvd Rw + Cd Rw
"Now i replaced the cables of the CD RW with that of the CD RW( 1 power cable, 1 for the parallel wires, and 1 wire comming frm the mobo)."
i assume u meant u replaced ur CD RW with your DVD RW drive
yes , u need to find two more such free slots to connect your 2nd drive.
both of them go into the respective slots at the drive end.
the other cable u are talking about could be tha audio cable that u connect to the audio port on the MoBo. usually used to listen to music thru the drive.(u need to plug in a headphone into the head phone jack on the drive.
could u post pics so that it can be confirmed.
now, to make it a secondary slave,u need to change the jumper settings.
the exact position should be given at one side of the drive.
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
