Old 30-04-2007, 07:01 AM   #1 (permalink)
Wannabe_a_techie's Avatar
Default Keeping it cool
In my room I don't have an AC....most summers I have trouble with overheating in my PC.
This time I went to the local dealer who sold me the assembled PC with this problem. He said that including a heat sink, extra fan, etc. was the usual way but suggested another method.
He told me to place a ice tray on top of the case, with a protective plastic sheet beneath. Said that since metal is a good conductor of heat this way my entire PC would keep cool.
I tried it and yes the fans became less noisy (meaning it was becoming cool).
As the ice melts, I quickly replace it with another, so that no water droplets are formed on the plastic sheets. Should I continue with this method of keeping my PC cool?
Wannabe_a_techie is offline
Old 30-04-2007, 09:34 AM   #2 (permalink)
Default Re: Keeping it cool
hahhah..........LOL
people go crazy cooling their system, the craziest method I posted about was keeping ur cpu in the freezer.
How much temp drop do u see before & after ice cooling..............download speedfan to monitor our temp.
On other thought if the plastic sheet is kept then it will reduce the conductivity, so better use some other conductive thin material like aluminum foil but which is water proof & ur ice bucket also should be of aluminum.
The alternative extreme method I read about ice cooling was keep the cpu in thermacol ice box & make a protective compartment of black pvc plastic to seperate the ice from the comp then cut the hole for fans & wires, this also works like a charm.
Here is the old post I posted.
Best cooling solution for hot delhi in may/june
Report back....................I am in need of cooling too, may soon buy extra heatsink fan.
ranjan2001 is offline
Old 30-04-2007, 09:51 AM   #3 (permalink)
assasin's Avatar
@Wannabe a Techie if u want to effectively cool ur pc without spending money,then keep a hi-speed table fan facing the inside of ur cabby.there sud be a temp drop of bout 10C.
else u can buy 3rd proccy coolers from CM or Asus.
assasin is offline
Old 30-04-2007, 11:10 AM   #4 (permalink)
darklord's Avatar
Hey Wannabe,
How is your cabinet's ventilation ?
darklord is offline
What you need for that?:cool: streetfire Hardware Q&A 1 08-11-2006 11:17 PM
Keeping Pc on during Lightstorm sysfilez Hardware Q&A 21 12-10-2006 08:03 PM
formating hard disk keeping all the installed programmes cybertooth QnA (read only) 6 09-09-2006 11:07 AM
How to keep the PC cool? NikhilVerma QnA (read only) 15 02-08-2004 10:24 AM
