Old 29-04-2007, 04:59 PM   #1 (permalink)
Question Suggest a mobo for my E6600
hi guys ,planning for an upgrade sometime soon ,need your help on this config
I'm planning on a
C2D E6600
RAM : 2 x 1 GB @667 Mhz ( Probably Kingston )
I'll be using this as an entertainment rig (= games,movies... ) and have no intention of setting up a SLI
I'm in a bit of a confusion about the mobo which i should use .
i'm looking for a board which would fully utilize my E6600.
i have these optionslz feel free to add if i missed anything
1. Asus P5B DLX
2. P5N32-E SLI
3. P5N-E SLI
4. GA 965P DS3P
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 29-04-2007, 05:05 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Suggest a mobo for my E6600
P5N32-E SLI is the best of the them all and costlier than all, hard to find in India, next comes, P5N-E SLI, and next P5B DLX, this one is widelly available...
whats you budget ??
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 29-04-2007, 05:23 PM   #3 (permalink)
Google Bot
Pathik's Avatar
@choto p5b deluxe is actually better than p5ne sli if u dont want sli.. And blacklight r u goin to take a gfx card or u want onboard gfx??
Pathik is offline
Old 29-04-2007, 06:52 PM   #4 (permalink)
assasin's Avatar
yeah P5B Deluxe is better than P5N-E SLi.
assasin is offline
Old 29-04-2007, 10:09 PM   #5 (permalink)
@choto:
my budget is around 10K .
@pathiks
yes, plan to get a DX10 gfx card in a few months time.
one concern i have is whether my ram would become a bottleneck while OC'ing on the 965 based P5B Deluxe Vs the 650 & 680 chipset where asynchronous memory overclocking is possible ?
Old 29-04-2007, 10:40 PM   #6 (permalink)
assasin's Avatar
^^^ hey see my rig's config in my sig.u'll get an idea.
assasin is offline
Old 30-04-2007, 12:31 PM   #7 (permalink)
hi assasin,
yup seems u are already a proud owner of a P5B Dlx board.
did u have any problems with the JMicron and Sound drivers ??
has Asus fixed them ??
Old 30-04-2007, 01:44 PM   #8 (permalink)
assasin's Avatar
no i dont hav any probs with the mobo.all required drivers r included in Vista,so i dont hafta install then separately.
assasin is offline
Old 01-05-2007, 01:00 AM   #9 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
P5B deluxe is a great motherboard...go for it if u don't want a n SLI (X32) setup.
keith_j_snyder2 is offline
Old 01-05-2007, 01:06 AM   #10 (permalink)
thankx guys ..especially assasin for helping me out .
planning to get my new rig as soon as the c2d prices are reflected here
best MOBO with E6600 anarchy0x Hardware Q&A 5 25-01-2007 12:18 PM
Suggest CPU & Mobo for a PC under 30k geek_rohit Hardware Q&A 8 17-12-2006 04:23 AM
Suggest Best Mobo for AM2 board boomstation2 Hardware Q&A 18 20-11-2006 02:34 PM
plz suggest intel mobo for cad/cam ashnik Hardware Q&A 2 07-02-2006 01:33 AM
PLS SUGGEST THE BEST MOBO, PROCESSOR, RAM !!! Vishal Gupta Hardware Q&A 28 23-11-2005 02:18 PM
