Old 29-04-2007, 01:11 PM   #1 (permalink)
Default Old Hard Drive For My New Athlon X2
Hey guys....I purchased Athlon 64 X2 3800+ with Asus M2N-E mobo. I got new WD 250GB SATA-II hard drive. Now I have old Segate PATA drive along with my old Sony DVD-RW which has also PATA interface. Now problem is that my mobo has only one Primary IDE connector. But I want to connect my old HDD and DVD-RW. How to do this....?
parimal is offline
Old 29-04-2007, 01:20 PM   #2 (permalink)
Sup' dude, Sup'
Default Re: Old Hard Drive For My New Athlon X2
Connect new SATA HDD to SATA port on the mobot.
You can connect both old HDD and DVD-RW to the IDE port on the mobo. You can connect two PATA devices to one pata IDE port
ambandla is offline
Old 29-04-2007, 02:12 PM   #3 (permalink)
That's true but I have to connect same cable on both HDD and DVD-RW. And the cable is too short to connect both of these devices....!!
parimal is offline
Old 29-04-2007, 02:18 PM   #4 (permalink)
Sup' dude, Sup'
Get a 80 pin IDE conductor cable from any PC hardware shop. It costs somewhere around 40 rupees.
ambandla is offline
Old 29-04-2007, 11:15 PM   #5 (permalink)
But how can I connect hdd and dvd on same 80 pin connector cable....it's too short man. I already got one with asus mobo.
parimal is offline
Old 29-04-2007, 11:20 PM   #6 (permalink)
darklord's Avatar
^^ I face the same problem with all new boards.
Well what you can do is connect the ODD to mobo IDE channel and connect HDD to a PCI IDE Raid card.Use it as IDE controller,thats what you can do sadly,no other way
darklord is offline
Old 29-04-2007, 11:34 PM   #7 (permalink)
assasin's Avatar
just try and keep the hdd and the optical drive as close to each other as possible.
assasin is offline
Why hard disk drive as removable drive? Sheik Rasheed K Hardware Q&A 6 25-03-2007 10:01 AM
xp on usb hard drive chahal63 Hardware Q&A 1 01-11-2006 08:28 PM
ATHLON 64 MOBO, SATA hard disk on Linux, dual boot godblessedson Open Source 3 17-06-2005 01:06 PM
Hard Drive toooo hard for 815 Sonu Yadav QnA (read only) 20 16-06-2005 03:55 PM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
