ive just bought a Lg dvd writer..
i donno...bt wenevr i insert ne cd or dvd in it...it runs too slw...getting my pc to hang...i want to knw the possible reasons for it...
if it is a hardware fault thn i ll get it replaced...
pls help me...
manan
^ check for DMA enabled,in windows....there is a device manager window.check there for the dvd drive listed and enable dma.if enabled,then also slow,then try a replacement.
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
Re: Dvd writer running too slow...
Enable DMA..
First right click ur my computer icon and go to properties.
Click on hardware tab and then on device manager.
There go to "ide controller".
In it cilick primary ide channel. Open its properties.
Go to advance settings. In tansfer mode select DMA if available.
Restart PC. Thats all.
If this problem persists try uninstalling cd driver for ur drive. Then reinstall it.
