my config:-
amd athlon64 x2 3800+
1gb ddr2 667mhz transcend ram
asus m2n pv-vm mainboard
onboard gfx
yamaha dx-xg soundcard
i use this soundcard instead of onboard audio
i just removed the soundcard once and used onboard audio
but next time when i fitted back the sound card i couldnt hear any sound
if i push in speaker cable completely in sound is cut-off, but if i push it in half sound
is heard with a lot of hiss
this wasnt happening before
and when i use bothe my speaker and headphones the sound comes in the main speakers, but not in the
in the headphones
and if i reduce the volume in my headphone completely, the speaker's volume is also cut-off
plz help out.
