Old 28-04-2007, 01:37 PM   #1 (permalink)
assasin's Avatar
Default Hp 250w Psu
guys today i got to lay my hands on a 250W HP original psu (2nd hand).the vendor's charging me 300 for it.its specs r:
+12V --- 14A
+5V --- 25A
+3.3V --- 18A
-12V --- 0.8A
+5VSB --- 2A Peak 2.5A
+5V & +3.3V ---- 165W max
+5V & +12V ---- 218W max
its running well in my config,heat dissipated is very low.the rail voltages being :
+3.3V ---- +3.23V
+5V ---- +4.94V
+12V ---- +11.72V
+5VSB ---- +4.90V
see my sig for my rig's config.
so wat do u ppl suggest,sud i buy it????
assasin is offline
Old 28-04-2007, 02:07 PM   #2 (permalink)
darklord's Avatar
Default Re: Hp 250w Psu
You want to use it in the Rig mentioned in your sig ? If yes then i i wouldnt recommend getting something better.
darklord is offline
Old 28-04-2007, 02:34 PM   #3 (permalink)
assasin's Avatar
yeah i plan to use it my rig which is mentioned in my sig.
i'm testing it now in my rig and its working fine.
prev i had odered 4 a Zebby 500w platinum buy had to send it for RMA twice.
it blew out the night i first got it.sent 4 rma and got it 3weeks later and again it went dead 2hrs later.both the times i had put my pc to 'sleep' mode and the psu went into eternal sleep...
i had tried the zebby psu i my prev rig which was a X2 3800+ and Asus M2N-MX.
so wat do u think i sud do???
assasin is offline
Old 28-04-2007, 03:06 PM   #4 (permalink)
darklord's Avatar
I really think you pass this off.You have a killer setup there and i think investing in a good PSU makes sense keeping in mind your hardware's safety.Why not go for Seventeam 500W which is available in Mumbai as well as Delhi.
darklord is offline
Old 28-04-2007, 03:14 PM   #5 (permalink)
assasin's Avatar
but it aint available in Kolkata.so cant lay my hands on one.
my budget for psu is 2.5-3k max.i cant find anything in that range.everythink is above 4.5k
assasin is offline
Old 28-04-2007, 03:29 PM   #6 (permalink)
darklord's Avatar
Get Powersafe 500Watt. THe golden coloured one made by L&C.It has a normal 80mm fan outside blowing air inside the PSU.
I have that in my ***** Rig and works like a charm. I donno if its available there.Its very good.It also has native SATA power cables and is EPS ready
I got mine for 2250/- only
darklord is offline
Old 28-04-2007, 04:01 PM   #7 (permalink)
assasin's Avatar
^^^ thnx dood
all guys living in Kolkata plz suggest what psu i'll get in 2.5-3k supporting Intel EPS 12v connector.also plz mention the name of the shop and the the contact number.
thnx in advance.
assasin is offline
Old 28-04-2007, 04:49 PM   #8 (permalink)
darklord's Avatar
^^^ thnx dood
thnx in advance.
See if you can lay hands on Coolermaster Xtremepower 600W.Its made by Seventeam make and shud cost around 3.5k or so
darklord is offline
Old 28-04-2007, 04:55 PM   #9 (permalink)
assasin's Avatar
^^^ but Classic Computer (vendor for CoolerMaster) quoted rates of 5.8k for igreen 500w psu and said rates will be higher for 600w.
assasin is offline
Old 28-04-2007, 06:52 PM   #10 (permalink)
No pain....No gain
john_the_ultimate's Avatar
@ assasin
"Classic Computers" did mention that they are soon going to stock Seventeam PSU.
john_the_ultimate is offline
Old 28-04-2007, 07:10 PM   #11 (permalink)
assasin's Avatar
^^^ do u know any other shop in kolkatta which cud stock good psu in my price range???
assasin is offline
Old 28-04-2007, 08:37 PM   #12 (permalink)
darklord's Avatar
Igreen power is expensive.Ask specifically for Xtreme power
darklord is offline
Old 28-04-2007, 09:27 PM   #13 (permalink)
assasin's Avatar
@john the ultimate do u know any place where i cud get powercolor psu?
assasin is offline
Old 29-04-2007, 03:05 AM   #14 (permalink)
No pain....No gain
@assasin
No idea about powercolor but VIP "powersafe" shud be available. Don't know about other shop dealing with CM products. You can look for CORSAIR HX
520W PSU @ Trirupathi Enterprises...........do check it out.......see if it comes within your budget. Other than that CM eXtreme Power is your best bet.
See more details of the CORSAIR PSU over here http://www.corsairmemory.com/corsair...er_supply.html
Old 29-04-2007, 08:56 AM   #15 (permalink)
assasin's Avatar
^^^ k.thanx.
i'll check it out.
assasin is offline
Old 29-04-2007, 09:34 AM   #16 (permalink)
Adhip007's Avatar
I dont think corsair 500w psu is available in kolkata, i had called them last week they said they have 620w psu costing rs 7200+ ,
@Assasin :
I have exactly same problem with zeb 500w platinum psu, now they r saying that it is not repairable, so they advised me to take he refund!!!
Also the shop which kept Powersafe SMPS is now closed forever!!
My new Config: Phenom II X6 1100T + ASUS M5A88M + Palit GTX 260 + 4GB Ram(Corsair Vengeance) + 200 GB(Hitachi) + 500 GB(Seagate) SATA+ 1TB external(Seagate) + Corsair VX550 W Smps.
ACER TravelMate 4740
http://www.flickr.com/photos/adhip_ghosh/
Adhip007 is offline
Old 29-04-2007, 09:59 AM   #17 (permalink)
assasin's Avatar
^^^ so wat do u plan to do now?which psu r u gonna buy?
so wat do u suggest which psu do i buy and from where?
assasin is offline
Old 29-04-2007, 12:27 PM   #18 (permalink)
Adhip007's Avatar
I am waiting 4 the zebby PSU to be return 4m service centre!! Now using an Cheap 500w PSU !! Actually i'm having Part2 Xam rite now, so i'm not using my computer too much!!
I have planned to buy CM! If it cost around 3K
Adhip007 is offline
