Old 28-04-2007, 12:35 PM   #1 (permalink)
Wink Decision for buying branded p.c.Advise needed.
After a long association with my desktop,for 7 years,I sold it off today.I need to purchase a new one at the earliest,but would go for a branded one since,it will be company sponsored.Can you please suggest branded p.c's for around 35,000/-,mainly to be used for internet work & gaming.Please do not suggest any AMD processors,since I have a very bad experience with AMD.Thanks a lot in advance.
harpoon is offline
Old 28-04-2007, 02:45 PM   #2 (permalink)
UbuntuUser
cynosure's Avatar
Default Re: Decision for buying branded p.c.Advise needed.
Desktops from Dell:
http://dellstore02.sg.dell.com/publi...19102445739435
DEsktops from HP:
http://h10010.www1.hp.com/wwpc/in/en...5-1116609.html
Desktops from Compaq (Its same as HP)
http://h10010.www1.hp.com/wwpc/in/en...5-1123043.html
Lenovo Family Desktops:
http://www-604.ibm.com/webapp/wcs/st...356&langId=356
Lenovo Business Desktops:
http://www-604.ibm.com/webapp/wcs/st...goryId=2056817
LG desktops:
http://www.lgezbuy.com/productlist.aspx?CatID=166
Wipro Desktops:
http://www.wipro.in/products/desktop..._per_list.html
And there was this ad in the newspaper in which the Intel PCs started from Rs. 19990. (+ Rs. 1000 for freight and installation)
Specs were:
C2D E4300
Intel 945GZ chipset based mobo
256MB DDR2 RAM
80GB HDD
15" CRT
Combo Drive
Keyboard/Mouse/Speakers.
Enjoy.
cynosure is offline
Old 28-04-2007, 03:05 PM   #3 (permalink)
Tech Geek's Avatar
Go for the dell E250
best one for that price
i heard they had reduced the prices for this month
so hurry up
Tech Geek is offline
Old 28-04-2007, 03:08 PM   #4 (permalink)
assasin's Avatar
i6ts hard to get a good branded pc for gaming in ur budget of 35k.
its hard to get a good branded pc for gaming in ur budget of 35k.better get a assembled one.
assasin is offline
Old 28-04-2007, 07:19 PM   #5 (permalink)
One bad experience with AMD and you are off it immediately? I have purchased many AMD systems in my office (mainly Sempron processors, but also a couple of AthlonXPs) and they work just as fine as my older computers did... I think that for lower budgets, you are better off going for AMD based systems as they have better Value For Money compared to Intel processors... Also, before C2D proccies, many P4 proccies had heating issues...
When it comes to gaming, an AMD based system will let you spend a bit more on your gfx card, thereby allowing for more balanced gaming experience...
I suggest Dell based systems for their configurability but the only problem with them is that there are no stores per se to purchase them or contact for service - you have to use the internet or call their customer service...
Arun
sakumar79 is offline
Old 02-05-2007, 02:30 PM   #6 (permalink)
Go for an ALIENWARE pc if u hav loads of cash..
alienspiesu is offline
help needed for buying ups mandar5 QnA (read only) 5 27-10-2006 09:18 PM
buying help needed GunshotSilence Hardware Q&A 5 18-03-2006 07:57 AM
Help needed in buying a pc of 35k duelmaster Hardware Q&A 8 11-02-2006 09:38 AM
Tv tunercard: Advise needed sanjaykulkarni QnA (read only) 13 02-08-2004 12:22 PM
