Old 27-04-2007, 11:47 PM   #1 (permalink)
Smile suggest me a good cpu....
I have a budget of around 12 k and i just want to make a C.P.U so can somebody suggest me a good cpu in this range i m not a big gamer and just i need ram 512 mb minimum n dvd combo n 80 gb sata else u suggest waitng for ur replies....and one more thing it should be a P4 no amd for me pls....
parag1985 is offline
Old 28-04-2007, 12:35 AM   #2 (permalink)
UbuntuUser
cynosure's Avatar
Default Re: suggest me a good cpu....
^^ P4's performce is not good dude, thats why AMD was a clear winner at the times of p4.
You should rather go for C2D even E4300 will give a decent performance.
Intel P4 3.0GHz: Rs. 3175
Gigabyte 865GSA Motherboard: Rs.2500
Dynet DDR 1 512 MB 400 Mhz: Rs. 1500
ComboDrive Sony. Rs.1300
SATA 80GB hardDisk: Rs 2000
CAbinet with power supply (400W): Rs.1500
Total: Rs. 11975
You can use slower P4 and this can reduca the price and can help you add some more hardware in you system.
Prices taken from www.theitwares.com
cynosure is offline
Suggest me a good PC for 25 k dinesh_mettur Hardware Q&A 11 22-12-2006 01:16 AM
suggest me a good pc for 25k dinesh_mettur Hardware Q&A 4 20-11-2006 07:49 AM
suggest something good....... sunny0384 QnA (read only) 3 21-12-2005 07:31 PM
suggest a good one pls! prash007 Buying Advice 3 27-09-2005 03:52 PM
Pls suggest good wap sites ram&byte QnA (read only) 3 29-05-2005 03:53 AM
