28-04-2007, 04:51 PM
17" CRT Monitor?
Finally decided on my Rig but now the bad luck part,Can't find my desired monitor which is Viewsonic E72f+ model.
Now all I need is opinions from existing Viewsonic & Samsung "CRT" monitor holders as to which latest model would be a good choice.As a high priority it needs to be a flat screen(duh!),supporting 1280x1024 @65Hz,must look absolutely gorgeous(preferably a equvivalent of E72f+  ).
Last but not least please don't start recommending any TFT models as I am seriously & I repeat,am seriously not interested in TFT's as of now.
Thanks in advance people.
V for Vendetta
Reason: Automerged Doublepost
28-04-2007, 08:33 PM
Fast 'N' Furious
Re: 17" CRT Monitor?
If you have to buy a CRT monitor then go for a 19" one.
I think text will be very difficult to read on a 17" monitor @ 1280*1024 reolution.
29-04-2007, 12:24 AM
Nothing like that i am On 1280*1024 reolution in vista no prob at all you just have to change the DPI settings
29-04-2007, 10:52 AM
Ummm....well I didn't mean setting the desktop resolutions to 1280x1024 but some games which could be set to that resolutions & hence the montior supporting it.Any recommendations? Please it's very urgent as I have to assemble it ASAP & this is the last component.Is LG any good or should I go with the usual Samsung 798MB plus?
V for Vendetta
29-04-2007, 08:24 PM
Location: If I had a webcam u could have seen me, before your eyes.
U mean LCD right and not TFT......
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
29-04-2007, 11:49 PM
those monitors r called TFT LCD.
29-04-2007, 11:56 PM
In search of light...
I have a LG Flatron E700SH 17" Flat CRT and am very satisfied. You can check this out as well.
http://abhijeetdeb.com
30-04-2007, 07:45 AM
mera kutch nahi ho sakta
65 is too low, it will give you headaches. 75 is the minimim refresh rate.
1280x1025 @85Hz will be acceptable. It might be difficult to find such a monitor though. Mine supports 1280x1024 @60Hz so I run it at 1024x800 @85Hz
Same here. Its nice but the refresh rate could be more.
jin files ka koi server nahi hota unka bittorrent hota hai
30-04-2007, 10:24 AM
^How's the quality till date that you have used it? Has it given any hicups?
Also is it fully flat CRT.Can you upload a pic of it if you can? I mean the one that you have with you.
V for Vendetta
30-04-2007, 11:36 AM
NO except sometimes it makes a lil peeeee sound for 10 seconds or so. This happens very rarely though, and is probably not a defect at all . The monitor is now 2.5 years old.
it is fully flat
30-04-2007, 11:45 AM
Thanks for the info pal.Will check if I can get hold of the Viewsonic model.If not then will try this option.
V for Vendetta
30-04-2007, 01:41 PM
I haven't had any hiccups at all. BTW my monitor's color is metallic black.
30-04-2007, 02:08 PM
@allwyndlima u can also hav a look at Lenovo flat 17" monitors before u buy.they hav a very good getup and the display quality is also crisp.
30-04-2007, 04:03 PM
Hmmm....Are they readily available in the market @assasin? I mean never head about Lenovo selling stand alone monitors.BTW I just called up Roop technologies to find out the stocks for E72f+Sb & then said that all Viewsonic 17" CRT's have stalled on stocks right now.
The only thing they could offer me were the 19 inch category which I found quite astonishingly low priced ones.For an E96f+Sb they quoted around 8.5k I suppose & the G90fB was around 9.5k.Now am really begining to bend my options.
V for Vendetta
30-04-2007, 05:08 PM
no Lenovo doesnt sell stand alone monitor,but dere will always be a dealer who'll be willing to sell u one.
03-05-2007, 06:39 PM
Fast 'N' Furious
I have already told U to buy a 19 inch CRT
