Friends my combo drive get eject smoothly but it stuck at last 5% at the way of insertion ,To insert i have to push the tray.Some body help me to get it perfect .
try aplying some vaseline on the side of doors.. means on tray... the sides of tray.. and then insert and open the drive about 10 times.. it will sort out.. and you can also remove any cabinet doors if you have one in your cabinet for CD drive out..
Its an LG drive right......I remember somebody flaming me for LG, samsung drives...for them LG is the best......haha....
I'd suggest (if that lubricant thing doesnot work) to carefully dismantle the drive clean it up and reassemble, that should do the trick(make sure its not under the warrenty). If nothing works get a new drive(this time Lite on or Sony) or live with it......
