Old 26-04-2007, 10:53 PM   #1 (permalink)
[A]bu's Avatar
Default My CDROM
my CDROM stops working when my pc's process will be 100%... what to do... the device manager shows no CD-ROM... and a thing that in any CD-rom there is written 52X but it is much lesser than we expect...
Any help for me
Do or Die
http://www.hamrobrt.com/howto-install-flash-player-in-ipad/
[A]bu is offline
Old 27-04-2007, 12:49 AM   #2 (permalink)
fff..fire fire...
Binay 007's Avatar
Wink Re: My CDROM
Any help for me
I can,t able to understand the above quote but i can suggest u to check urs drive cable before rebooting ,cable may be losed,last time same thing happening to my HD too & it was not detected.
P4 2.93(GHZ) ,256 RAM,LG combo drive ,915GL-V mobo
DLink/intex int. modem
Binay 007 is offline
Old 27-04-2007, 01:46 AM   #3 (permalink)
shantanu's Avatar
Default Re: My CDROM
its possible that your CD drive cable is loose and or your SMPS is weak, just try to check the cable and try getting a greater watt power supply.. as when 100% usage is there, the system consumes more power and your pc is unable to give adequate power to the CDROM.. and you can also try to check if your system is infected by any virus or all system files are ok or not..
but main reason is power.. that i am sure about..
shantanu is offline
Old 27-04-2007, 03:35 PM   #4 (permalink)
UbuntuUser
cynosure's Avatar
Any help for me
This all depends on the speed at which the CD was burned. Like if the CD was burned at 48x, then your ROM will read it at 48x only and not at 52x.
In some cases the speed of the ROM is preset at 40x.
So in those cases open the tray, load the CD and keep the button pressed for 7-8 seconds. This will activate the 52x read feature of the ROM.
But I think this feature is only in burners and not in ROMs. correct me if I am wrong.
cynosure is offline
cdrom help bharat Hardware Q&A 3 02-04-2006 07:48 PM
No cdrom and no HDD skrbhatt Open Source 7 08-09-2005 10:53 PM
Linking the cdrom?? curvenger Open Source 3 11-07-2005 05:19 PM
no cdrom in 98 sAr QnA (read only) 5 27-04-2005 09:04 PM
cdrom & RW help ??? ax3 QnA (read only) 1 22-11-2004 06:17 PM
