Old 26-04-2007, 05:31 PM   #1 (permalink)
Default Voltage problem..
guys. plz chck the pictuire.. the Voltage shows as 1.74 where it should be between 10 and 13.. nd the system fan is shwwn as 5443.. whereas it is actualluy CPU fan.. i mean fan attached with the Procesor... plz help....
http://rapidshare.com/files/28013891...lem...doc.html
Windows XP Pro Service Pack 2 build=2600
Mobo- MSI PM8M-V
GenuineIntel Intel(R) Pentium(R) 4 CPU 2.40GHzRAM : Installed : 512 * 2 MB DDR RAM (TRANSCEND)
XFX FX5200 128 MB
medigit is offline
Old 27-04-2007, 02:19 AM   #2 (permalink)
shantanu's Avatar
Default Re: Voltage problem..
the file you sent is corrupt... and why it is in DOC format... hey r u sending a virus..
shantanu is offline
Old 27-04-2007, 11:35 AM   #3 (permalink)
why d u thnk its a virus.. ???i hv paste the pic in the word document...
nd the file i hav uploaded is alright... no problem.. Is nyone having problem in opening the file??
Mobo- MSI PM8M-V
XFX FX5200 128 MB
medigit is offline
SMPS Voltage low midhunmon Hardware Q&A 3 23-08-2006 02:09 PM
SMPS Voltage drop stops AGP from working? midhunmon QnA (read only) 3 23-08-2006 03:10 AM
Athlon64 3000+ showing odd voltage drvarunmehta Hardware Q&A 7 28-05-2006 09:29 AM
+3.3 Voltage problem. System restart prashantisonline Hardware Q&A 1 26-11-2005 01:03 AM
CPU Over voltage geek007 Hardware Q&A 4 25-11-2005 03:08 PM
