Old 26-04-2007, 10:17 AM   #1 (permalink)
jayanbhm's Avatar
Default processor performance 100% ????????
Dear friend,
Iam using a PIV machine 915 gv chip set, 40 gb IDE HDD 256+128 MB RAM 2.66 GHZ processor my problem is that when ever i try to use some higher end appliction that is movie maker ,games, opening more than one word or pdf file (even during copying also) the processor fan will make a big sound and the processor performance became 90 to 100% and more over the pc will became dead slow and even go to hang (majority of the processor perfomance is using for system idle process)
suggest me the exact reason for this even i changed processor fan and smps still the same problem
hope some body will suggest me the best
with thanks
jc
jayanbhm is offline
Old 26-04-2007, 10:26 AM   #2 (permalink)
Sup' dude, Sup'
Default Re: processor performance 100% ????????
Install "speedfan" and monitor temperatures. I think 50-60 temperature is normal. If you see very high temperature, better adjust the heat sink or you can apply thermal paste. You can get brnaded thermalpastes (arctic silver, coolermaster etc) for 300bucks or more.
ambandla is offline
Old 26-04-2007, 01:59 PM   #3 (permalink)
jayanbhm's Avatar
thanks dear let me try once
jayanbhm is offline
Old 26-04-2007, 05:22 PM   #4 (permalink)
56561's Avatar
whats the normal tempearture for a processor?
56561 is offline
Old 26-04-2007, 05:24 PM   #5 (permalink)
Sup' dude, Sup'
Depends on the processor. Not just Intel or AMD. It depends on model and make of the processor.
ambandla is offline
Best performance from RAM mananknl Hardware Q&A 6 06-12-2006 10:26 PM
Win xp tweaks for max performance blademast3r Tutorials 8 24-10-2006 10:57 PM
what will be the performance 56561 Hardware Q&A 8 02-10-2006 02:05 PM
PC performance Trinity Software Q&A 1 25-03-2006 09:49 AM
How much overall PC performance diff by add 512 MB ram nikdesign4u Hardware Q&A 14 21-03-2006 12:44 AM
