Old 26-04-2007, 09:04 AM   #1 (permalink)
56561's Avatar
Thumbs down when i am starting my PC cabinet-light starts blinking
when i am starting my PC cabinet-light starts blinking, nothing else is happening , nothing on the screen ....no sound....nothing . whats the problem ?
56561 is offline
Old 26-04-2007, 09:09 AM   #2 (permalink)
Super Saiyan
Goten's Avatar
Default Re: when i am starting my PC cabinet-light starts blinking
Check all of ur cables coz they might be loosely attached.
Peace~~~!
Goten is offline
Old 26-04-2007, 09:21 AM   #3 (permalink)
Search for Adventure
ITTechPerson's Avatar
Hope it's not a mobo failure signal
Nobody is Perfect. I am "Nobody"
ITTechPerson is offline
Old 26-04-2007, 09:33 AM   #4 (permalink)
Sup' dude, Sup'
reset BIOS by removing the CMOS battery.
Reinsert RAM
Check the power connections.
ambandla is offline
Old 26-04-2007, 10:41 AM   #5 (permalink)
assasin's Avatar
pwr on ur pc using another psu.most probably its either a psu or a ram prob.
take out ram,clean both module and slot and re-insert ram.
assasin is offline
Blinking Power Led keep_it_rl Hardware Q&A 8 07-04-2007 08:04 PM
Hdd light blinking ! ! ! ax3 QnA (read only) 6 18-05-2006 11:34 AM
LED blinking,no picture phatratt Hardware Q&A 6 23-02-2006 12:58 AM
Monitor and Monitor Power Light is blinking aathif QnA (read only) 4 21-05-2005 05:20 PM
Starting a program as soon as winows starts..... abhi_shake Software Q&A 2 03-04-2005 11:57 AM
