Old 24-04-2007, 07:53 PM   #1 (permalink)
Default DVD Writer Problem
I bought a Sony DVD-Writer bout 6-7 months back..it worked fine wen i used it first time. but after that time till now, im experiencing a problem.
it is taking arnd 1hr or so to write a DVD. irrespective of the speed i give.. may it b 8x/12x/16x
My system configuration is P4, 2.8HT, 256MB RAM, Intel 865 board.
I tried these following things but no change..
  • Increased RAM to 512 then 768.
  • Re installed the Operating system.
  • Booted from other friends hard disk.
  • Loosen all bolts and then tried… and then took it out of system and put on the cabinet.
  • Created atleast 4GB space in the C drive.. (Windows drive) where NERO is installed.
Please help me regarding this. Im facing too much trouble cause of that.
Reply ASAP.
salil_belani is offline
Old 24-04-2007, 08:12 PM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Default Re: DVD Writer Problem
You have done everything except touching your DVD writer. Maybe its lens needs cleaning. Get its lens cleaned.
navjotjsingh is offline
Old 24-04-2007, 08:15 PM   #3 (permalink)
Security Exp
47shailesh's Avatar
Alternatively try updating the Firmware of ur H/w
We Love Once, And When We do We do it Well
47shailesh is offline
Old 25-04-2007, 06:23 AM   #4 (permalink)
shyamno's Avatar
From where the lens can be cleaned...??? r u telling to use lens cleaner.....
shyamno is offline
Old 25-04-2007, 07:13 AM   #5 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Check the ATA cable.It might be the problem.Also in device manager check whether ur writer is in ultra-DMA mode cause if it's not then surely the cable is the problem.If u do not get any of these as the problem then get ur drive serviced,it will for sure solve ur problem.Do not play with the firmware for now.
Harvik780 is offline
Old 25-04-2007, 01:02 PM   #6 (permalink)
Still Shining!
Lucky_star's Avatar
This problem has been discussed here a lot of times and I have given the replies around 10-20 times. Please search before posting. This is a general problem with all DVD writers.
Just reset your DMA. Use this tool: DMA RESET
OR Change the DVD cable(that ribbon type) with a HD cable.
It should solve the problem. I have done this a lot of times.
Nokia N86 8MP
Lucky_star is offline
Old 16-05-2007, 11:30 AM   #7 (permalink)
hey all...
i appologise for replying late....
thanks for all ur replies... i really appreciate it...
i installed fresh windowz and cleaned the lens with lens cleaner...
now the DVD Writer is working fine..
jus one problem my frnd has passed on to me.. that when he tried to write in DVD.... some of them were burnt properly.. but some got failed when it approached to the end..
i m unable to make out what could be the possible reason for that..???
plz help me in that...
is it a DVD disc problem... or DMA problem or....??????
Old 16-05-2007, 12:12 PM   #8 (permalink)
Search for Adventure
ITTechPerson's Avatar
the speed of writing dvd should vary with system speed, if u have 256 ram u may not able to write 16x (it is not happen to everybody but with somebody)
Nobody is Perfect. I am "Nobody"
ITTechPerson is offline
Old 16-05-2007, 12:26 PM   #9 (permalink)
but im able to write d DVD on 16x speed...
infact hav burnt 4 DVD on that speed.... but the problem comes is some times.. 2 times to b precise... it failed while it was approaching the end...??
m not able to undrstnd this....??? y this happened...??
Old 16-05-2007, 01:02 PM   #10 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
mayb defraging might help a bit & write @ lower speeds ........ hope it helps ...
ax3 is offline
Old 17-05-2007, 10:46 AM   #11 (permalink)
cooldip10's Avatar
1)Cleab the lens
2)Check the ATA cable.
3)Do a firmware update.
4)Then rock on!!
Everything is Possible
cooldip10 is offline
Old 17-05-2007, 04:34 PM   #12 (permalink)
Still Shining!
Lucky_star's Avatar
Simple DMA problem, nothing else.
Reinstalling Windows restored the DMA.
Next time, don't go for reinstalling XP again.
Nokia N86 8MP
DVD writer problem... shyamno Hardware Q&A 8 03-04-2007 04:54 PM
CD writer problem aritrap Hardware Q&A 1 03-12-2006 04:05 PM
DVD Writer problem RaceDilepa QnA (read only) 8 21-12-2004 09:21 AM
Problem with DVD Writer sourabh_nandi QnA (read only) 3 26-08-2004 07:22 PM
