24-04-2007, 12:37 PM
666
Heat Is On! Give Your Readings!
Guys.. give your thermal readings along with your specs in this thread.. Mine is..
Cabinet Temperature: 28c / 34c
P4 3.0Ghz CPU Temperature: 50c/60c
WD 250 SATA II Harddisk Temperature: 35c/40c
6600LE 256MB PCIe Graphics card: 50c/60c
Environment(the place where i live) Temp: 32 deg c (Average yearly)
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS
24-04-2007, 01:34 PM
Re: Heat Is On! Give Your Readings!
I am sure that I will top this list.
Location Delhi
present room ambient temp 35/40c
cabinet peace zebronics 500w PSU with big fan temp 38-45c
CPU c2d E6300 54/56c ideal ..............on load 63-67c
Seagate hdd 250 sata2 46/53c
xfx 7600GT GPU PCI-e 62/68c
24-04-2007, 02:16 PM
Location Bangalore
Present room ambients ~ 25-26C
Coolermaster Stacker 830, Watercooling
C2D E6600 @3.6GHz/1.41V
idle 42/44
loaded with apps 47/48
temps with TAT 55/56 (the max possible temps)
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
24-04-2007, 06:32 PM
Location Durgapur
Room Temp - 30-33 C
C2D E4300 @ 3GHz/1.38v/Stock HSF
Idle - 27-30
load - 55-58
WD 160 GB 35/40
6600LE 256MB Pcie - 45-50
24-04-2007, 06:40 PM
Master Chief
Location Varanasi
Room temp 35-37 C
Celeron D 320 - 41-42 idle/47-48 full load with Stock Hsf
HDD Seagate 40 GB 33-36 C
24-04-2007, 09:26 PM
Back to l33ching :)
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
Location - Kolkata
Room Temp - 29-32 c
amd 64 3000+ at 55ºC idle/ 66ºC on full load
seagate pata 120gig 52 ºC
seagate sata 120gig 50 ºC
are the temps too high? suggestions for keepin my rig cooler?
btw, am using SIW to take the temps
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
24-04-2007, 10:28 PM
 .. temps are infact cooler during summer with the AC  ...
24-04-2007, 10:40 PM
Back to l33ching :)
^^very funny
but seriously are they too high?
24-04-2007, 10:57 PM
^^^ yeah the proccy temp seems to be a bit high.it sud be bet 30-40 at idle.
hdd temps sud be bout 35-40.
if ur cabby is small then get a bigger airy cabby,also fix some xtra fans...
24-04-2007, 11:37 PM
Back to l33ching :)
ok..lets c....any cabby suggestions? n range?
25-04-2007, 12:05 AM
u cud go for Zebronics Peace or Antibiotic cabbies.they'll set u back by 2.4-2.6k with psu.deduct 400 bucks from price if u dont want psu.
25-04-2007, 12:14 AM
Originally Posted by gauravakaasid
^^very funny
Dude i was talking about my case  ... look at these temps ... i get these at idle ..
25-04-2007, 05:10 AM
Deathvirus,
what is your cabby & what is your ambient temp? I am using speedfan4.32 but your screen shows all fans, in my case it only shows CPU fan, my Peace cabby has 4 fans, how can I monitor that in speedfan
do we need to set some options somewhere in speed fan or mobo to show all the details. I doubt my mobo fan sensors are not working as they should.
25-04-2007, 10:17 AM
^^^ speed fan will only show u the rpm of all fans that r connected to the mobo fan headers.it wont show the fans which r connected directly to psu.
25-04-2007, 11:38 AM
It means that my fan connector are not working, I had another cabinet where 4 fans were connected to the mobo but it was not showing any reading, I need to get that checked.
25-04-2007, 12:10 PM
Learner
Location - Kolkata
Room Temp - 29-32 c
Dude... u are killing your HDD's. I wouldn't be surprised if ur nothbridge is running hot too, u need to change your case or something.
just open the sidepanel and blow a fan toward the case, and let us know the temperatures then.
25-04-2007, 02:50 PM
does enabling dual channel ram increase them proccy temp???
today i installed another ram stick and enabled dual channel ram.
slot 1:1GB ddr2 667 (5-5-5-15/4-4-4-12)
slot 2:1GB ddr2 533(5-4-4-12/4-4-4-12)
by default both ran @ 533 and wudnt oc,so i manually adjusted the timings to 5-5-5-12 and now both r running @ 667,proccy @ 3GHz and dram:fsb = 1:1.but the overall effect is that my proccy & mobo temp has increased by 2-3C.
any ideas why this is happening???
will this setup damage my mobo???
25-04-2007, 03:17 PM
Debian Rocks!
Room temp:31degrees
Processor p4 prescott 2.8Ghz temp=+40°C (low = -1°C, high = +127°C) sensor = diode
@ max =50
Motherboard Asus via chipset temp=+40°C (low = -1°C, high = +127°C) sensor = thermistor
seagate sata 80gb hdd : Temperature_Celsius 0x0022 049 053 000 Old_age Always - 49 degrees
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
25-04-2007, 04:45 PM
#19 (permalink)
Assasin, when u OC u have to do it manually in the BIOS, & that does increase the temp too, enabling dual channel has no effect as per my knowledge in temp increase.
25-04-2007, 04:58 PM
#20 (permalink)
^^^ when i've only the 667 stick inserted den i dont hav to manually set the timings even after oc.but this prob is only with the 533 stick.its wont oc beyond 533 without manually setting the timings to 5-5-5-15.
so wat do u suggest i return the 533 module and get a 667 one?
25-04-2007, 05:12 PM
#21 (permalink)
I am not aware of this problem, lets start another thread for this problem, timing can only be set manually by disabling the SPD timings in BIOS thats what I know.
How are u OC with single stick?
There is an OC thread where u might find lots of info, its posted by sam9s
25-04-2007, 05:15 PM
#22 (permalink)
^^^ oc is perfect with the 667 module.timings r auto set @ 4-4-4-12.but the prob arises when i insert the 533 module.the pc wont post if i dont manually set the timings to 5-5-5-15.
25-04-2007, 07:13 PM
#23 (permalink)
mixing 667 & 533 is not a gud idea, 1st get 533 replaced with the 667 same paired ram, I thing the problem is with different frequency ram in dual channel.
25-04-2007, 09:10 PM
#24 (permalink)
now both rams r working @ 667 4-4-4-12.
so is there any need to replace my 533 stick???
25-04-2007, 09:40 PM
#25 (permalink)
My understanding is that the higher 667 ram will be scaled down to 533 else it cannot work in dual channel, so yes u need to have same config paired ram for sure, either 667 or 533.
25-04-2007, 10:04 PM
#26 (permalink)
Back to l33ching :)
@Kniwor n assasin....thnx for us suggestions...lets c wat i can do.
but it has to wait till the weekend, dnt have time nw
#27 (permalink)
Sup' dude, Sup'
config:
AMD Athlon 64 venice 3000+ 1.8 GHz Overclocked to 2.5GHz.
2x512MB Transcend DDR 400 overclocked to 450MHz approx.
Seagate SATA2 160GB.
Zebronics Geforce cabinet with 2 Cooler Master HSF.
sytem: 35
CPU: 41
AUX: 46
HDD: 45
Core 47
room temperature: 28
25-04-2007, 10:32 PM
#28 (permalink)
Originally Posted by ranjan2001
Deathvirus,
what is your cabby & what is your ambient temp? I am using speedfan 4.32 but your screen shows all fans, in my case it only shows CPU fan, my Peace cabby has 4 fans, how can I monitor that in speedfan
should.
I use a Antec PlusView II cabby ... check it out here :
http://www.techenclave.com/forums/ri...llery-265.html
About ambient temps .. i didn't get ambient temps in the cabby itself .. but my room temps were 25-26c as i had the AC running ..  ...
Also , to properly monitor the temps , ur fans must be connected to the mobo via the chassis fan connectors ..
25-04-2007, 10:55 PM
#29 (permalink)
Learner
dude.... ur posts are totally confusing, to take some sense, tell us what FSB are running the board at, then tell us if the ram is running at 1:1 or higher or lower, and then we will have there mere info of what ur ram is running at and a suggestion can be made.
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
heat sink
xbonez |
Hardware Q&A |
10 |
30-03-2007 11:40 AM |
Heat sink
saurabh DH |
Hardware Q&A |
3 |
27-03-2007 09:23 AM |
How hot is the heat-ray gun?
rajasekharan |
Random News |
1 |
25-02-2007 02:46 PM |
Cpu Heat
abhighost |
Hardware Q&A |
11 |
22-09-2006 05:25 PM |
Heat!!!!
direct_2d |
QnA (read only) |
14 |
25-07-2005 04:00 PM |
