Old 24-04-2007, 09:55 AM   #1 (permalink)
Sup' dude, Sup'
Default Samsung RAM Modules?
Hi There,
Does anyone know where I can get Samsung Memory modules for Desktops in India.
I thought Since they are the world's largest manufacturer of Semi conductors, their RAM should be really good. Need some unbiased suggestions.
ambandla is offline
Old 24-04-2007, 11:51 AM   #2 (permalink)
assasin's Avatar
Default Re: Samsung RAM Modules?
afaik Samsung ram modules r hard to get.
i had one in my Compaq pc
assasin is offline
Old 24-04-2007, 06:30 PM   #3 (permalink)
My Corsair Value Select 400 1GB modules contain Samsung chips.
V.Prem Kumar
janitha is offline
Old 24-04-2007, 09:27 PM   #4 (permalink)
Sup' dude, Sup'
afaik, samsung chips are found in each and every electonic item. RAM, HDD, displays, Optical drives, ipods, mp3 players....
ambandla is offline
Old 24-04-2007, 10:58 PM   #5 (permalink)
assasin's Avatar
^^^ the most common ram chipset used r from Hynix.
assasin is offline
samsung why so Official Techie Mobiles and Tablets 26 18-08-2006 12:56 AM
How many RAM modules should I go for? kunalmg Hardware Q&A 11 02-07-2006 01:47 PM
Installing Ram Modules n.regmi Hardware Q&A 8 22-06-2006 08:23 AM
RAM Modules --- Help Needed rockthegod Hardware Q&A 20 03-12-2005 08:07 PM
