Old 22-04-2007, 08:46 PM   #1 (permalink)
Default FX 5200 on vista
hey guys i got query will vista run smoothly on fx5200 (256) if yes is it worth buying it @ 1500 bux. thnx in advance...my budget is 2k as i dont play any games...
amit gala is offline
Old 22-04-2007, 09:03 PM   #2 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Default Re: FX 5200 on vista
U don't need a graphics card to run windows vista.The graphics are for the people who wants the max. pleasure out of the operating system.U can run VISTA on an onboard display.
keith_j_snyder2 is offline
Old 22-04-2007, 09:50 PM   #3 (permalink)
@keith_j_snyder2
thnx for ur advice..
i m using K8 MM-V quite basic board with 3000+(754).. dint find any vista drivers on Msi site for it so dint go forward for installing vsta...
Old 22-04-2007, 10:21 PM   #4 (permalink)
Rising ApocalypsE
U don't have to go on MSI site.AFAIK ur motherboard has a VIA chipset so i think u should go to the VIA site.
I have founf this & i think it might be helpful http://www.viaarena.com/?PageID=2
This one too:
http://drivers.softpedia.com/get/Oth...410-WHQL.shtml
Have fun Dude!
Last edited by keith_j_snyder2; 22-04-2007 at 10:21 PM. Reason: Automerged Doublepost
Old 22-04-2007, 10:22 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
well the xp drivers will work fine in vista. only disadvantage being you won't be able to use the aero interface. but make sure that u haf at least 768mb ram and 64mb of shared graphics memory. otherwise overall experience will be quite sluggish.
infra_red_dude is offline
Old 22-04-2007, 10:26 PM   #6 (permalink)
shantanu's Avatar
and dont buy 5200 @ 1500 coz 6200 is at 1700/- (pci-e) 128 mb.. so say no to 5200 @1500/- you can get a second hand 6200 @ 1500/- i think... or you can try 6600GT or 6800 (second hand)
shantanu is offline
Old 22-04-2007, 10:27 PM   #7 (permalink)
Cool G5's Avatar
Arrow Re: FX 5200 on vista
I also have a via onboard chip.I installed vista & it was running satisfactorily.Only thing is you won't get the aero interface.Also you will not be able to play movies.(It will play like a slideshow)
My configuration:
Processorentium 4 @ 2.0 GHZ
Mobo:MSI PM8M-V
Ram:768 MB(64 shared by onboard gfx)
Cool G5 is offline
5200 mostwanted Mobiles and Tablets 3 17-12-2006 02:28 PM
Problem with FX 5200 honey62022 Hardware Q&A 11 06-08-2006 09:33 PM
FX 5200 TV OUT vaibhavlovegames Hardware Q&A 2 25-03-2006 09:55 PM
Help for Fx 5200 nagesh435369 Hardware Q&A 1 04-03-2006 11:30 AM
different 5200......!!!! manmay QnA (read only) 1 04-10-2004 10:31 AM
