Old 22-04-2007, 03:16 PM   #1 (permalink)
Default please help me
hello my dear friends i want your help in buying a computer i want to know which is better Assemble or bran ded.Kindly answer .
shriram_jairam is offline
Old 22-04-2007, 03:58 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: please help me
Assembled
Your budget ?
Third Eye is online now
Old 22-04-2007, 07:05 PM   #3 (permalink)
my budget is 23000
Old 22-04-2007, 07:32 PM   #4 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
there should be a sticky for these type of queries....there are atleast >10 posts about this everyday
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 22-04-2007, 07:49 PM   #5 (permalink)
a_g = JPKN
s18000rpm's Avatar
for trouble free computing, get a Branded one.
as your budget is low, then Branded PC is out.
get a Assembled one, & ask about the details (which m/b, proc., RAM....) in this thread itself, pls dont create new thread
& make sure you BUY a Original Windows XP for TROUBLE FREE Computing.
dont go for Pirated XP/Vista..., better get LINUX [which is free]
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 22-04-2007, 08:28 PM   #6 (permalink)
Learner
Kniwor's Avatar
Assembled
Kniwor is offline
Old 22-04-2007, 09:10 PM   #7 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
If u have a fair knowlidge of hardware then go for Assembled but if u don't know the ABC then buy a branded one but assembled one are better because they provide u more warranty and is also economical whereas BRANDED are costly and maximum companies gice 1 year warranty but if u want to extend ur warranty then u have to pay more.
Another thing if u know someone personally who is a well wisher and actually a vendor then go for assembled one.
keith_j_snyder2 is offline
Old 23-04-2007, 02:21 AM   #8 (permalink)
ASSEMBLED- increase ur budget to 30k and go in for c2d..
azad is offline
Old 23-04-2007, 02:33 AM   #9 (permalink)
If you really want a good configuration and have a problem with assmebling then that shld'nt be a prob at all you can contact www.theitwares.com those guys asslemble it for just Rs. 500/- !!!
kooldude is offline
Old 23-04-2007, 03:14 AM   #10 (permalink)
Learner
Kniwor's Avatar
A 30k c2d will really be a very bad choice.
Kniwor is offline
Old 24-04-2007, 09:57 PM   #11 (permalink)
Rising ApocalypsE
u can go for C2duo for 30K budget but INTEL's new offsprings E6320 & E6420(30)...something like that are good one with same config. but with 4MB L2 Cache.I m not sure if they are on the shelves but they were supposed to be of the same prices.
Otherwise get a 5600+ which beats E6300 straight up.
Check this out http://www.theitwares.com/processors/processors.htm
Now buy E6320 ($MB L2 Chache) its better than anyone & a killer buy!!!!!!!!!!!!!11
Old 24-04-2007, 10:50 PM   #12 (permalink)
Learner
Kniwor's Avatar
blah..blah..blah...
pls suggest a 30k config for c2d
Kniwor is offline
Old 24-04-2007, 11:05 PM   #13 (permalink)
assasin's Avatar
@keith j snyder dood its true that the C2D proccy prices hav come down but the prices of the mobos havent.so to get a good mobo u'll hav to spend to the tune of 10k.so it sums up to bout 16-19k for mobo & proccy.also most of the high end C2D mobos dont hav onboard gfx.that means xtra investment on gfx card.
assasin is offline
