22-04-2007, 09:55 AM
P5B Deluxe WiFi-AP
hi guys
i got my new mobo & proccy yesterday.its a C2D E4300 and Asus P5B Deluxe WiFi-AP Edition.and Altec Lansing VS2321.
everything is running just fine but i've one question:
does Asus bundle the eSata cable along with the mobo pack or do i hav to buy it separately???
my mobo came with 6SATA,3pwr cables,a fan,USB & firewire header,Q-connector.
is anything missing from the bundle???
Also wats the diff bet AHCI and RAID settings in the BIOS
22-04-2007, 11:47 AM
Re: P5B Deluxe WiFi-AP
Ur content of the box is same as mine so I guess that what is all is bundled along with it.
Content of the box is mentioned on the box or instruction manual either one of it.
AHCI,
when I enabled AHCI then I found slight performance drop testing with HD tach..............so be fully informed before you switch to AHCI....................I would say that u dont need it.
http://www.intel.com/technology/serialata/ahci.htm
http://en.wikipedia.org/wiki/Native_Command_Queuing
22-04-2007, 05:36 PM
How much did the Mobo cost you?
22-04-2007, 06:43 PM
The High 5 Flyer
Originally Posted by assasin
hi guys
Content looks same except include the wifi antenna as well........
PS:: Whats the current price of ASUS P5B Delux Wifi......
22-04-2007, 09:22 PM
^^^ yeah i forgot to mention the array mic and wifi antenna.
the mobo cost me 12.8k.
AHCI sux.RAID 0 is far better.
does any 1 know how does the Altec Lansing VS2321 stack up against the ATP3.i felt the sound of the former is better so i got it.
today i sold off my X2 3800+ and Asus M2N-MX for 10k.
i've hit the 3GHz mark with vcore @ 1.163(stock),idling temp of 30-33 and under full load 55-57.mem ratio is 1:1.
r the figs ok??????
22-04-2007, 09:53 PM
The High 5 Flyer
r the figs ok??????
mmm the mobo has not gone down too much I got it for 13K. So you planning to OC your machine, I'd say you must giv it a try, lets see how well we can stretch 4300. Virtually there is no difference between 4300 n 6300 except the VT disabled, so this makes 4300 a great buy and its overclocks equaly good to 6300 if not better.
I sold of my p4 2.2 Ghz with Intel D850MV for 10K as well but I had a geforce 440MX in that as well.
Good to see your rig......start OCing......
Hey assasin check this out interesting article to read....
http://www.techspot.com/review/40-co...-overclocking/
22-04-2007, 09:56 PM
I think u can enable AHCI only for NCQ drives to get better performance .. otherwise it' won't make any diff.
Did u actually reformat for that ?? If u enable AHCI i think ur Hdd won't be detected until u install the RAID/AHCI drivers .. which is only possible if u reinstall XP ?!! ...
I got it for 11.6 + VAT ...
RAID 0 is much better performing , but if u reformat u'll lose all the data .. AHCI along with NCQ will give enough performance for one to miss RAID if he/she is more biased at data security (rather protection) ...
22-04-2007, 10:04 PM
In my case both my seagate hdd support NCQ feature I checked with HD tune.
On asus forum I read that we can enable AHCI without the need of reformatting & I used that method sucessfully installing the new drivers.
So dont know how AHCI is better than IDE, in theory it should be be but I tested & saw slight performance drop with both hdd.
22-04-2007, 10:17 PM
u got the wifi version for 11.6k????
23-04-2007, 09:42 AM
Yup ..... right here in kolkatta ...
23-04-2007, 10:36 AM
Hey Assasin, Congrats on your new System !
I think the price for the board is a bit on the higher side.Anyways,Best wishes for your overclocking endevour !
23-04-2007, 11:39 AM
planning on the same board but without wifi available for 10.2 k at theitwares wondering if this gfx card will work??? http://www.newegg.com/Product/Produc...82E16814102068
also advise if u go in for the asus pwdh board will it work on tht too?? thx!!
23-04-2007, 11:58 AM
Originally Posted by joelf15
that card will work on both the boards you have mentioned.
23-04-2007, 01:52 PM
@deathvirus me did u get it from Rashi in kolkata??
my vendor said he got it from Rashi @ 12.8k.if 11.6k is the price then i'll hav to bargain with him......
23-04-2007, 04:12 PM
Most probably my vendor got it from Rashi ... i have my ways  ... so got it for slightly less ... actually , the price was even higher when i got mine  ..
24-04-2007, 11:09 PM
in which 2 slots sud i install the ram modules so as to enable dual channel mode.i'll get another 1GB stick 2morrow..
25-04-2007, 12:18 AM
Alternate slots ...  .. u should have read the manual ..
25-04-2007, 12:33 AM
dont hav that much time.i'm a bit busy now a days
25-04-2007, 04:21 AM
#19 (permalink)
The High 5 Flyer
Alternative slots. usually the slots are color coded so you need to install RAM on the same color slots for it to work in dual channel mode.....
29-04-2007, 02:58 PM
#20 (permalink)
one more Q:
i'm getting BSOD if i use AI NAP after my proccy is oc'ed to 3GHz but is working perfectly if i use it @ stock speed.any solutions?
also if i'm playing a song and then using AI NAP the song is not playing perfectly.
i'm using Vista Ultimate
2nd prob solved.
some1 plz help me out with the first prob.
Reason: Automerged Doublepost
29-04-2007, 03:16 PM
#21 (permalink)
Google Bot
hey assasin wats the price difference between the p5b deluxe and the p5b deluxe wifi ap???
and i m thinkin to go for a new pc soon...
so i m thinkin whether to go for
1. asus p5b deluxe + e4300 + 8600gt
2. asus p5n e sli + e6300 + 8600gt..
i wont be using SLI nytime...
also is the asus p5n e sli a good overclocker???
does it come wit the same OC options as the p5b deluxe???
my budget for mobo+proccy+gc is arnd 20-22k.. pls suggest..
also gimme any other mobo within 8-10k which is good for OCing... no SLI needed..
also assasin do u OC ur proccy just wit AI gear or using any 3rd party app??? i m new to OCing.. and can we adjust the multiplier and fsb from ASUS OC PROFIle???? if not.. then how do we go about it??
and do u think that Intel VT is really needed???
and can i OC if i take a DG965RY??
darklord,deathvirus and sam9s ur opinions also needed..
29-04-2007, 06:49 PM
#22 (permalink)
price diff between P5B Deluxe and P5B Deluxe WiFi-AP is bout 2-2.5k.
P5N-E SLI is also a good overclocker.but has a few drawbacks:
1>no heatsink on SouthBridge,
2>passively cooled Northbridge which tends to run very hot if FSB is increased beyond 400.
3>mobo has FSB holes in the range of 400-450.
other than that the mobo is ok.
u wont be able to fit all 3 in 22k.
mobo + proccy will cost u bout 16-18k.so u'll hav to inc u budget.another good OC mobo is Gigabyte DS3P but it doesnt hav e-Sata support.
i'll suggest u to go with ur 1st option.
i oc thru the bios.i dont use any apps to oc thru windows.
u can adjust both the multiplier and fsb both from bios and from windows thru AI Suite.
VT is not needed.
u cant oc DG965RY.
29-04-2007, 06:53 PM
#23 (permalink)
Google Bot
wat say abt asus p5b vm and p5n 32 e sli?? Is it a better overclocker than p5b dlx
29-04-2007, 06:58 PM
#24 (permalink)
if u wanna oc then dont go for mobo with integrated gfx (like P5B VM).
P5N32-E SLi will be a better mobo than P5B Deluxe.but it'll cost u more than P5B Deluxe WiFi-AP and is hard to find.
29-04-2007, 11:50 PM
#25 (permalink)
Google Bot
do u mean that p5b vm is a bad overclocker or it doesnt overclock at all?? Cant i reach 3ghz+ wit my 6320 under 1.3vcore on a p5b vm?? Actually if i get a p5b dlx then i ll hav to get a gc.. And that ll overshoot my budget.. So wat do u say of p5bvm+ 6320??
29-04-2007, 11:54 PM
#26 (permalink)
i'll suggest u to buy P5B DLX instead of P5B VM.dont compromise on the mobo if u wanna oc.
just borrow a spare gfx card (even old pci ones will do) from one of ur frnds or from ur vendor and use it untill u buy a gfx card.
30-04-2007, 12:16 AM
#27 (permalink)
Decent overclocking and Mobo with onboard graphics generally DO NOT go hand in hand.There are a few exceptions like AMD 690G. But i am yet to come across an Intel chipset with embedded GPU clocking like MAD.
As assassin says, P5B Deluxe is a very nice board.You will be surprised to know,it is the most favourite mobo of most of the legendary overclockers.
It is like the Asus P4C800/P4P800 or Abit IC7/IS7 of Socket T.
P5N32-E is excellent but has some quirks.Heat being major one.
Otherwise excellent OC board.When it comes to Memory clocking, there is no competition to 680i SLI chipset.
30-04-2007, 01:12 AM
#28 (permalink)
U updated the bios yet ??
Under 2k's .. but the WiFi feature in not worth it unless u really have a situation where u an actually use it
Well , for 22k's ... hmmm .. i can only suggest the following combo : E4300 + MSI P965 NeoF + 8600GT .. only then will it come down in 22k's ... my friend runs his E6600 on a P965 Neo at 3.0 GHz stable , so oc'ing is not a problem .. u won't get too many settings to mess around with ..
It is always recommend to OC from the BIOS itself ...
Not really , atleast not for general desktop users ... u should disable it anyway if u do plan to OC
Not sure ... but i think u can't .. only the 975XBX and the XBX2 does for Intel i think .. not sure though ..
30-04-2007, 09:37 AM
#29 (permalink)
^^^ i've updated the bios to version 1101.
30-04-2007, 09:47 AM
#30 (permalink)
I remember that some of the asus utility such as AI Nap does not work when u r in OC mode & they reduce the ower to cpu & fans & hdd so its fine if they dont work in Oc mode.
