Well I tried the KX driver... and had a lil problem though
Even though my speakers fared well when i did "Speakers Test" you know all the speakers were recognized and sound came.
But when i was playing Mp3 or something... i will only hear sound coming from the Front pair (the rear had nothing... )
By the way... the speakers were "reversed as they told... you know swap the front to rear... and rear to front".
Help.... anyone ?
Well , KX should install 4 devices for ur sound card at a single time .. numbered as 0/1 , 3/4 etc. etc. .. check out which one is selected under "Sound Properties" in control panel ... then select that respective one in the player ur using to play the song (Winamp eeh ??) ...
Okay... okay !!!
Well Yes I am using "Winamp 5" to play my mp3.
So when you say 4 devices for my sound card... does that mean something like 4/4 (means 4 channel for 4 speaker something... he he he see I'm soo confused)
