Old 21-04-2007, 06:57 PM   #1 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Default Help Me out - RAM
I have a pc with
INTEL 915 GV chipset & an intel p4 processor 519( Intel EM64T.3.06 Ghz, 533 Mhz FSB, 1 MB L2 cache)
now i want to upgrade the ram to 1gb. plz tell whch ram should i use and also the price. also tell whether i should go for two pieces of 512 mb ram or a single piece and of what frequeny will suite better
currently i have 256 mb ddr2 ram at 533 mhz
skippednote is offline
Old 22-04-2007, 08:28 PM   #2 (permalink)
Default Re: Help Me out - RAM
hi cap'n neo,
ur M/B supports dual channel DDR2 ram ,so go for
DDR2 - > 2 X 512 MB @533 Mhz for better performance.
brand - u could go for transcend ,they offer lifetime warranty.
other options are kingston .U could go for OCZ or Corsair if u r into overclocking.
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 22-04-2007, 09:06 PM   #3 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
If u are a gamer then u will require DUAL CHANNEL but if u are a casual user then there is no need to buy 2 sticks then buy a single 1 GB stick.
Also in dual channel u will hardly notice a difference but only in gaming.
keith_j_snyder2 is offline
My Old Box Needs Upgradation aku Hardware Q&A 1 13-09-2006 11:12 AM
help me in upgradation of pc.,,,,, mkmkmk Hardware Q&A 7 18-12-2005 05:18 PM
Upgradation Raaza QnA (read only) 10 29-08-2005 07:23 PM
Upgradation to AMD 64 bit. Help! narangz CPU / Motherboards 14 28-05-2005 03:43 PM
PC upgradation upendra_gp QnA (read only) 15 27-05-2005 10:23 AM
